Cefiro Retrofit Mini Write-up
Old Nov 7, 2005 | 07:22 AM
NCSU_MAX's Avatar
Maximoneypit
A couple guys have asked me how difficult this was so I figured Id post a few pics of the process. The cool thing with the cefiros is that you dont have to cut the reflector out to fit the projectors in. From the beginning;
1: The old oven trick to get them apart (about 15 min at 275)
2: Once youve got the lense off unscrew the reflector from the back of the headlight (2 screws)
Old Nov 7, 2005 | 07:24 AM
NCSU_MAX's Avatar
Maximoneypit
3: From here simply place the projector in the reflector and add the bezel
My bezels originally held two lights so we dremeled it down to a cirlce.
Old Nov 7, 2005 | 07:28 AM
NCSU_MAX's Avatar
Maximoneypit
4: Now for the only real cutting you'll have to do - theres a circular tab going around the back of the housing (just dremel it off)
I bought some JB weld but never had to use it bc everything fit so snug and the bulb holder sandwiched the projector to the reflector. from here it was a little left to right adjustment by hand of the projector but thats about it before the lenses go back on.
Lemme know if you guys have and questions
NOTE: Much thanks to Mad-Max_SE who was the ingenuity behind alot of this
Old Nov 7, 2005 | 08:03 AM
Iron Scimitar's Avatar
Tha Snatcher
curious....why did you place the projector in from the front and not the back? did you use a shroud?
Old Nov 7, 2005 | 08:13 AM
bayvillian516's Avatar
what kind of projectors are those? and yea i have the same question as iron
Old Nov 7, 2005 | 09:27 AM
Hectic's Avatar
too much herb man...use in moderation. it's cheaper that way too
Old Nov 7, 2005 | 09:34 AM
NCSU_MAX's Avatar
Maximoneypit
by opening them from the front we were able to just slide them in w/out cutting out the back. With the cefiros the reflector is independent of the housing so instead of cutting through both the housing and then the back of the reflector we just stuck the projector in from the front putting the bulb holder through the hole that was already cut for the intended h4's.
Old Nov 7, 2005 | 09:35 AM
NCSU_MAX's Avatar
Maximoneypit
BMW 745 bi-xenon
Old Nov 7, 2005 | 09:41 AM
NCSU_MAX's Avatar
Maximoneypit
yea Iron i used a shroud from a mercedes (see one of the above pics) sorry its from the side. Heres a better one
Old Nov 7, 2005 | 01:05 PM
gtr_rider's Avatar
192.168.1.1
nice...
Old Nov 7, 2005 | 01:12 PM
NCSU_MAX's Avatar
Maximoneypit
thanks gtr rider.
heres a pic of the bezel and where we cut it. we actually turned it upside down inside the projector so the flat part was on top (giving it a more menacing look)
Old Nov 7, 2005 | 01:16 PM
streetzlegend's Avatar
oh man thats very nice and clean. cuz some people that do retros get very sloppy. but its cuz of all the cutting. thats great. im not a fan of the cefiro housings but those look nice with that bezel and projectors. i cant wait to find a damn shroud lol my retro looks bad wen u look inside cuz i got aluminum tape as a bezel lol. w/e works the output is awsome so it dont matter. good job
Old Nov 8, 2005 | 07:17 AM
hey hectic thats pretty funny you said that, cause i dont even remember writing the reply lol
Old Nov 8, 2005 | 04:51 PM
RA030726's Avatar
I'm nutty for Nissans
it would be mint if the cefiros fit he 4th gen with out gaps. nice job on the lights, do you think you can install them in the car and make it look good?
Old Nov 8, 2005 | 06:27 PM
NCSU_MAX's Avatar
Maximoneypit
i already installed them
http://forums.maxima.org/showthread.php?t=438730
Old Nov 8, 2005 | 06:51 PM
Nickel's Avatar
those are tuff as ever man
could you get the lights in difrent color??
Old Nov 8, 2005 | 07:20 PM
NCSU_MAX's Avatar
Maximoneypit
you can get different K bulbs which will change the color but HID bulbs will change color at the different angles that you look at them depending on how good the projectors cutoff is
mine actually look kinda purple at the cutoff but bluish white otherwise
Old Nov 9, 2005 | 02:16 PM
RA030726's Avatar
every pic of them installed is the same. you should have taken above and side photos as well. but they do look great from the front.
Old Nov 9, 2005 | 02:21 PM
NCSU_MAX's Avatar
Maximoneypit
^^^ youre right, not sure why i didnt get more from the side. I hope to go do some more soon w/ some pics of the cutoff as well
Old Nov 11, 2005 | 05:18 PM
lex4style's Avatar
very impressive...i might try something like this in the spring.
Old Nov 12, 2005 | 10:42 AM
Rowan's Avatar
Nice, very clean! May I politely request mods sticky this so the newbs can look at it instead of asking the same questions?
Old Nov 12, 2005 | 07:28 PM
kingofsorrow's Avatar
NCSU_MAX first off, they look great. 2nd are you able to adjust you're beam? or has the retrofit cost you that option? i mean can the you still move the beam higher or lower using the adjuster on the back of the headlamp?
Old Nov 12, 2005 | 08:40 PM
NCSU_MAX's Avatar
Maximoneypit
thanks guys!
kingofsorrow - once the projector is in the reflector the only movement you have is left to right (actually positioning the projector). Once its in place left to right you can use the 2 screws in the back of the headlight to adjust the height. you should be able to aim them pretty perfectly by doing this.
heres some final pic in case you missed the thread. im going to try to have a pic of the beam pattern soon.
Old Nov 13, 2005 | 10:04 AM
thanks NCSU, i plan on putting some 350Z projectors or maybe some Q45 projectors, in my lamps so i really needed to know about control of the beam. once again the install looks super clean, great job.
Old Nov 21, 2005 | 10:03 AM
juani's Avatar
Rockin' VK56!!
looking good
good to have another projectored cefiro headlight.
Old May 10, 2007 | 12:47 PM
cmb5286's Avatar
what happens to the city lights?
i have these on my I30
just wondering if i could still use them
Old May 10, 2007 | 08:32 PM
KsuMax's Avatar
Cheesing away...
jesus, you have to bump up a 2 year old thread, don't you?
Old May 11, 2007 | 03:03 AM
cmb5286's Avatar
**** you im new
Old Oct 23, 2007 | 10:33 AM
one_fast_max's Avatar
i know this is an old thread but i had some questions...
doing this custom projector headlight are you using the maxima headlight housing or the cefiros? and how is the projector wired up ??
Old Oct 23, 2007 | 05:32 PM
4MySwee's Avatar
You get smart with someone bumping an old thread, but if these folks had asked about a Cefiro retrofit, how many times do you suppose they would have been told to "Search"?????......
Old Oct 23, 2007 | 09:08 PM
bkmax98's Avatar
sexy *** retro
Old Oct 24, 2007 | 11:51 AM
i have searched for the answer to my question but i can't find anything....and it didn't say anything on the vqpower website. but how are these lights hooked up? i imagine there is more than just splicing involved....so could some one enlighten me please! thanks!
Old Oct 24, 2007 | 04:26 PM
4MySwee's Avatar
Send a pm to the OP NCSU_MAX. He is very knowledgeable about this.
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
03VQMAX
Nov 10, 2015 03:39 PM
Excalibur23
Oct 13, 2015 04:33 PM
Vistance
Sep 17, 2015 05:17 AM
