Help
Old Jun 4, 2001 | 03:18 PM
Moe's Avatar
Moe
I put in my stillen intake and now I have this whistling noise when on the gas in certain gears, I get the mean *** grumble put in the higher gears there is a whistling and a noise that sounds like someone inhaling through their lips real quick. Is this normal, everything is tight I checked. Please help. Also, I set off the check engine light b/c I forgot to put the MAF back in is there anyway to reset it? someone told me to take the EFI fuse out for a minute but I don't know which one it is............
Old Jun 4, 2001 | 04:28 PM
tunedup's Avatar
i believe that is hte noise it makes
my intake whistles a bit tooo.
The EFI FUSE Is under the hood
i dont know if its on the right or left side but u cant miss it
it is labelled
Electronic fuel injection
i dont know if that will do the trick with the Check engine
but i know the way i resetted it was with the ecu
u get a screwdriver and u turn the ecu screw a full rotation counter clockwise adn then all the way clockwise back...
the ecu is located near the gas pedal there a panel with two clips that you must remove the ecu screw is enclosed by some safety tape.
if there is anything else please post.
