Atten Daniel B, Suspension Problems that would cause my tires to wear really bad
Old Jun 4, 2001 | 08:16 PM
GTRBlkMax97's Avatar
Any ideas, I just got my set of Kumhos and the fronts have worn really bad, whereas the backs are like new. The other set of tires I had on my car did the same thing. Thanks in advace for your help
Old Jun 4, 2001 | 09:10 PM
AznWontonboy's Avatar
do u need an alignment?
Old Jun 5, 2001 | 01:33 AM
Eric L.'s Avatar
Um, the fronts generally wear quicker than the rears. If you rotate your tires every 10k miles, you will get more life out of your tires. If you are getting uneven wear on one tire (i.e. more wear on one side, etc..) then you need an alignment or you are not inflating your tires properly. If you drive aggressively, you will wear out the edges of the tread very quickly.
Old Jun 5, 2001 | 04:12 AM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
LOWER BALL JOINTS. they were bad on my last car and i killed a new set of tires in like 10K or less miles, and they were a 60K miles tire.
Old Jun 5, 2001 | 08:21 AM
Well to make things a little clearer, the car is aligned perfectly, got it done when I put the new kumhos on. i do my fair share of hard cornering, but the tires are worn evenly, the fronts have maybe 2000-3000 miles on them and they are worn to half of what the rears are. So what would a lower ball joint going bad sound like?
Old Jun 5, 2001 | 08:27 AM
hmmm, when the lower ball joints went it was uneven wear on the tires, this might not be what it is but if you jack the car up you can tell, see if the wheel has any play in in from top to bottom. push the top in and out and see if there is play. that's the first sign.
Old Jun 5, 2001 | 09:08 AM
Max_Gator's Avatar
If they are worn like that, there isn't anything wrong. Sounds like hard driving on low treadwear tires to me. Go get them rotated. They are only gonna last 15k - at most.
Old Jun 5, 2001 | 09:34 AM
but the first set of tires were high treadwear and they did the same thing
Old Jun 5, 2001 | 10:44 AM
dwapenyi's Avatar
I noticed with my Pirelli 7000 supersports, with their really high tread wear rating of 320 AA, the fronts still wore out way faster than the rears. It was as if the rears weren't doing anything at all, just rolling!!
You gotta rotate your tires regularly, like every 5 K miles, especially if you have V or Z rated tires that are unidirectional, so your tire rotation can only be front to back, back to front etc, no criss crossing.
DW
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
FlaMark
25
Aug 28, 2015 10:15 AM
