Help With Rear Shock
Old Jun 8, 2001 | 05:32 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
OK i got the new spring on the rear shock and now i can't even get the shock hole CLOSE to the mount. WHAT DO I DO TO MAKE IT FIT, it's getting dark and i'm pretty well screwed!
Old Jun 8, 2001 | 06:21 PM
Mishmosh's Avatar
Can you describe the problem a little more?
You mean the lower mount or the upper one to the trunk?
Also, why exactly do you think things aren't going back in?
Old Jun 8, 2001 | 06:23 PM
Sonic's Avatar
Don't worry about it, he got it to work.
Old Jun 8, 2001 | 10:33 PM
emax02's Avatar
If Medics right then ignore my post. What I think happend is when you put your shocks/springs on your Strut tower mount thingies you threw it out of allighnement. The best way to get it back into alighnment is to twist the top of your suspention{the ST thingy} back into place. It's been a while but I believe there is only 3 possible combinations, one of them is correct and the other two a wrong.
Old Jun 9, 2001 | 04:45 AM
I know
I know what you are talking about and i fixed that, i figured out that you need to turn it. But I had the car jacked up by the rear axle so the distance between the whole were the shock goes and the mount was small. i put the axle on jack stands and then jacked it up by the spare tire well and it open up the distance and went right in. now i just stripped the last bolt on the other side. car looks funny, three lowered corners!
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Violator
Sep 9, 2015 10:14 AM
