Is there any getting around cutting off these nuts?
Old Feb 11, 2006 | 04:29 PM
BigLou93SE's Avatar
About a half a year ago, I installed my FSTB, and realized I needed to fit washers underneath the FSTB brackets in order to have the bar comfortably clear the engine. When reinstalling the FSTB, and torquing the Strut Mount nuts to spec, two of the six stripped. Besides cutting them off and replacing the bracket, is there any way of getting these nuts off?
You can see which ones I'm talking about. (not my car)
My current plan is getting my power drill and a cutting wheel and cutting those two nuts off, and then replacing the bracket and nuts when installing my suspension over spring break. Are there any other suggestions?
Thanks,
Lou
Old Feb 11, 2006 | 05:22 PM
CreativeDesignz's Avatar
u could get a stripped nut removal set from sears they work like a charm
Old Feb 11, 2006 | 10:39 PM
nismos14's Avatar
§è~® f®ÈÄk
Ya before cutting I would get the removers.
Old Feb 11, 2006 | 11:04 PM
BigLou93SE's Avatar
Would this allow me to reuse the old bracket and/or nuts? I'm going to go search sears right now, but how much would these run me?
Old Feb 11, 2006 | 11:07 PM
BigLou93SE's Avatar
Ok, I realized that my explaination of what the "stripped nut" has led to some confusion. By "stripped", I meant that the nut spins freely on the stud. The hex on the nut is completely fine, but the nut spins freely both to the right and to the left. Is there any way around this?
Old Feb 12, 2006 | 06:59 AM
dremel that bietch off with a cutting wheel it might mess up the threads more. then u may need a tap and dye set to re thread that bolt
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
