Where do I buy my guages?
Old Jun 13, 2001 | 03:30 PM
bosco500's Avatar
I was looking around and cannot find a pod to hold the guages for a max. I would like to have the one that runs down the left side of the window/windshield, or either one that fits under the cd player. Probably getting boost, a/f, and FP. Also what kind of guages are good and who sells them? thanks
Old Jun 13, 2001 | 03:37 PM
The New CLIMAX's Avatar
I believe the gauge pod for the 4th gen maxima for the pillar is #20802. You may wanna check www.autometer.com for check gauges, that's what I have, or for more expensive ones you can get Apexi, or greddy, etc.
Old Jun 13, 2001 | 03:47 PM
mtrai760's Avatar
'Trynna' is not a word
I got all my gauges at www.summitracing.com They are pretty reasonable, but it helps if you search through there stuff for a while, because some gauges are a lot cheaper than others, and do the same exact job. To mount them under the CD changer, you will have to get some black ABS and do a custom install, but it shouldn't be too hard. Good luck.
Old Jun 20, 2001 | 11:42 AM
bosco500's Avatar
Climax -
Do you only have 2 guages on your pillar? Would it be possible to put a 2 guage pod, and then a single guage pod on the same pillar so you could have 3 guages?
Old Jun 20, 2001 | 12:14 PM
Climax -
Yes it would be possible to do that, have a 2 gauge pillar and a single and make it 3.
I have all 3 or my gauges, Boost, EGT, and Fuel Press. under my aftermarket CD player, if you have the stock BOSE CD/tape player you will not be able to fit them there. But if you changed out your deck, you should be able to do a custom job to make them all fit there. I chose not to put them in my pillar b/c it loses the sleeper affect. And you will have all sort of 4 bangers wanting to race you, and even the big 8 guys. This way I choose who I race, and I surprise them.
Old Jun 20, 2001 | 12:26 PM
Jane97SE's Avatar
Used force to obtain Admin powers
Can you please tell me what size the guages are? TIA
Old Jun 20, 2001 | 12:31 PM
Cumalot's Avatar
And this is bad? I plan to get a supercharger too. When I do, I'll put the gauges on the pod. Strange, I don't have much stuff in my car now, but I don't get many people racing me. Maybe they think I'm slow and not worth it? Or I often drive like a nut case and they're afraid I'll hit them?
Old Jun 20, 2001 | 02:50 PM
D-DOT's Avatar
Nopi sells the one that goes under the cd player it's made by HKS ane it holds 3 gauges the nopi# is 981+1997 and the HKS# is 5404-sn002 and the cost is 26$. I know your form ATL,so just to let you know I work at Nopi in Forest Park and we only have 2 left.
Old Jun 20, 2001 | 02:58 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
But.....
I think it only holds 43mm gauges which is too small to hold the traditional 2-1/16 Autometers.
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
