Help... Overscrewed OEM oil filter
after i realized that i it tightened up again when i kept screwing clockwise, i screwed it counter-clockwise and got it off without any problems. my threading looks fine, so i screwed it back on again, this time being sure I had a flashlight there so i can actually see what im doing instead of going at it blindly - like i did the first time, and everythin was fine.
Originally Posted by foodmanry
So you initially cross-threaded the filter and it righted itself on the threads? Hmm...have you tried removing the filter altogether? If you haven't I think you'll find yourself in a bind when you go to do that as you have stripped half of the threads.
Originally Posted by Frank Fontaine
Somehow this entire post makes no sense. I know I've done my oil about 14 times and I never came across any difficulty screwing on the filter. There's no way it can go on any way but the correct way. It cannot start on at the wrong angle. I remember way back when when I was a kid, a more experienced friend told me, "there's only one way it can go in," and in the case of the filter, on.
Originally Posted by acidspit86
does no one use an oil filter wrench? it will help you more than you could imagine, and has a lot more leverage than your hands
1.) theres simply no need if u do things right and oil the gasket
2.) just risks doin more harm than good
Originally Posted by trigger005
ugh... thats exactly why i do NOT use an oil filter wrench
Originally Posted by Hoooper
i think he meant to get it off... at least i hope he did. if not, then acid you seriously need help with your automotive business, the oil filter is only supposed to be hand tight when you put it on. if you use a filter wrench you run the risk of overtightening and having a big problem.
hahaha, naw man of course i meant to get it off. but then again, if your crafty like i was one day, you can make an oil filter wrench out of an extension cord and double sided tape, just loop it around the filter and hold the two ends of the cord in your hand and turn/tug in the counter-clockwise way, oh yeah, double stick tape to make the cord stay gripping the filter
Don't need it. Anyone who has a tool box is gonna have Channel Lock or imitations. They work very well in removing the oil filter. Why buy an unnecessary tool that just costs more money and takes up more space? Less is more.
You should know that men don't own any "unnecessary" tools.
get those open wrenches that are adjustable to remove the filter and check that o ring as mentioned. I"ve never lubed the ring before and i never had a leak. I"m guesing there are two rings. That sucks cause i hate doing my own installs and have something bad come out of it.
Since the filter's overscrewed, any kind of rotating motion won't work... since its completely loose when you screw it either direction now so I'm not sure how tools would really help me. I see the only way is for me to try and twist it out... just hope I won't damage the threading on my oil pan.
getting a strap wrench is still a good idea for loosening a oil filter. if you use the same types of filter get a oil filter key from pep boys, you can attach a sprocket to it.
Originally Posted by MrGone
This is the ghetto approach to working on cars and does an awesome job creating headaches.
http://www.channellock.com/acb/store...ier_P140C5.cfm
220k+ A32
18
Sep 22, 2015 11:39 AM
JoshG
51
Sep 21, 2015 10:41 PM
aminus21
Sep 12, 2015 04:53 PM
