where to buy "adjusting cap"
Old Apr 9, 2006 | 10:06 AM
ThurzNite's Avatar
I'm looking for the part called "adjusting cap" in this picture. Kragen calls is "spindle retainer". Where can I order this part for cheap?
Jae
Old Apr 9, 2006 | 10:11 AM
njmaxseltd's Avatar
You can either buy a nut with splines on it so a cotter pin holds it in place or get that cap from Nissan.
Both items should be under a buck........
Old Apr 9, 2006 | 10:57 AM
RA030726's Avatar
I'm nutty for Nissans
its called a castle nut.
Old Apr 9, 2006 | 01:31 PM
1FSTMAX's Avatar
its not a nut though...
it's an axle nut retainer...
Old Apr 9, 2006 | 03:25 PM
njmaxseltd's Avatar
+1 for the correct name.
You don't need that retainer if you use a castle nut instead.
Again, it should be around a buck at most local auto parts stores.
Old Apr 9, 2006 | 03:32 PM
Matt93SE's Avatar
STFU n00b!
DO NOT use a castle nut on your front axles. use the right parts from Nissan or equivalent. a castle nut is NOT the right part to use to hold your wheel bearings together.
those retainer rings are cheap. They're $0.92 list from Nissan.
the nut itself is only $4.13 list.
Old Apr 9, 2006 | 07:00 PM
RA030726's Avatar
WTF is the difference? i have seen them both ways. is my wheel going to fall off?
Old Apr 9, 2006 | 07:40 PM
Matt93SE's Avatar
STFU n00b!
I have yet to see a castle nut installed from the factory on a Maxima.
The wheel bearings are fragile enough on these cars that I would be very wary of using anything that you have to torque to spec, then continue tightening until you get to an opening on the castle nut. it can possibly ruin the wheel bearing before you even finish putting the car back together! :
Old Apr 9, 2006 | 08:28 PM
1FSTMAX's Avatar
what would be the torque spec for the axle nut Matt?
Old Apr 10, 2006 | 04:15 AM
RA030726's Avatar
hmmm, well i cant remember what car i replaced tha axle on but it didnt have the adjusting cap.
Old Apr 10, 2006 | 10:18 AM
Matt93SE's Avatar
STFU n00b!
170-230ft.lb. Just as stated above.
With the common failure I see on wheels bearings with 3,4,5,6th gens and the VERY common occurence of the 5th and 6th gen axle nuts backing off, you want to run them right at max torque. go much over and it's possible to crack the inner race.. go under and the thing backs off, ruining the wheel bearing from slop in the hub. unfortunately it's a lose-lose situation with Maxima wheel bearings.
Old Apr 10, 2006 | 10:21 AM
Matt93SE's Avatar
STFU n00b!
Probably yet another cost-cutting measure from Nissan. I noticed they were gone on the 6th gens and I think 5th gens as well. And they're the most common to kill wheel bearings. I've seen several cars come in with the axle nuts only being held on by the cotter pin. fortunately I hade a few retainer clips laying around in my spares bucket and stuck them on those cars after they came in a second time with loose axle nuts (even after replacing the bearings and torquing them to spec). Add the retainer clips and no more loose nuts.
Old Apr 10, 2006 | 04:56 PM
RA030726's Avatar
youre the boss, thanks for the info. im surprised my dads bearings are still good then.
Old Apr 10, 2006 | 05:37 PM
Matt93SE's Avatar
STFU n00b!
I've seen it go both ways. some torqued to 1000+ft lb and won't break loose, others that crack at 250. At $200 a bearing and hub to replace, I'd veer on the side of caution. :shrug:
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
