Possible bent wheel?
Old Jun 13, 2006 | 03:25 PM
AsthmaMax11's Avatar
I am getting this terrible vibration through the steering wheel at around 70 mph ever since I put these wheels on. I have balanced the hell out of the tires and rotated the tires around as well.
I noticed some road rash on two of the wheels as well.
What is the worst that can happen from a bent rim?
Old Jun 13, 2006 | 04:10 PM
FanaticMadMax's Avatar
if the rim is bent, as siginficiantly, then you need a new rim. But since you said a rash, it doesn't really affect it much, how many miles did you put on the tires, since tires usually are the one that is about to blow. again, you have to check the tire speed rating. since if you have a tire rating of letter H or higher, then you can go over 75 but if it's under,that's probably why you getting vibration.
Old Jun 13, 2006 | 04:46 PM
Greeny's Avatar
¯\(°_o)/¯
One or more of your tires may out of round...They will balance out on the machine,but will ride like you have a egg for a tire..
Have the tire shop dismount the tires,then put the wheels on the balancing machine to see if they balance out...
Old Jun 13, 2006 | 05:04 PM
njmaxseltd's Avatar
Hub-centric rings much.....
Old Jun 13, 2006 | 06:16 PM
I had the same tires on my previous wheels and could cruise at 95 all day without any problem. they have about 5k on them.
wouldn't this cause visible uneven wear as well?
So if the wheel itself is out of balance on the machine then it is definately bent?
they're worth a shot. Where would you recommend I buy them?
Old Jun 13, 2006 | 06:31 PM
Frank Fontaine's Avatar
They're on both sets of my aftermarket rims, but I'm not sure how much they do, because when you think about it, when you line up the studs through the holes, there is play...then I suppose that play in in a circle.
I have visible damage to one rim and was thinking about checking this place out, it's the cheapest I could find...
http://fixrim.com/wheel.htm
Old Jun 13, 2006 | 07:51 PM
QnzMax's Avatar
Yes...you will definitely be able to tell if the rims is bent like this. When I got my rims, all 4 were bent. I got them fixed and now theyre perfect.
Old Jun 14, 2006 | 03:54 AM
Greeny's Avatar
¯\(°_o)/¯
Not always...An out of round condition on a tire is hard to spot just by looking at it...I have seen several tires look fine to the eye,but when it was put of the balancer you could see the wobble....
Old Jun 14, 2006 | 04:05 PM
Hey I appreciate everyone's advice with my problem,
especially njmaxseltd. He has always posted good advice to my question threads!
Fbana41
Aug 29, 2016 12:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
