Can this be done?
Old Nov 7, 2006 | 03:48 PM
Y2KMaxGXE-R's Avatar
Can this be done?
A lot of 5th genners are struggling to solve the P0430. Can any of the companies that make aftermarket exhaust to Maximas fabricate a piece that would replace the Bank 2?
The OEM piece is just ridiculously overpriced and junkyards will not sell because of some law not allowing to sell used emissions components.
Old Nov 8, 2006 | 08:14 AM
bump to the top
what, no one has the answer?
Old Nov 8, 2006 | 10:36 AM
oldngivout's Avatar
Willing to learn
I've seen one on Ebay before, don't have the link handy.
Just search for maxima catalytic converter.
Old Nov 8, 2006 | 01:09 PM
1FSTMAX's Avatar
um use a fed spec y pipe, in conjuction with an o2 sim? well that's what i do.. no codes..
Old Nov 8, 2006 | 04:44 PM
do you even know what P0430 stand for? It has nothing to do with a y-pipe, its the precat part on the other side of the main cat
Old Nov 8, 2006 | 05:15 PM
Mass_Media's Avatar
Mass_Media™
Its the precat part on the other side of the main cat?
If your talking about precats then a y-pipe would affect it as 5th gen (00-01) are on the y pipes.
Old Nov 8, 2006 | 07:40 PM
1FSTMAX's Avatar
this is what it means..
CausesA code P0430 may mean that one or more of the following has happened:
The catalytic converter is no longer functioning properly
An oxygen sensor is not reading (functioning) properly
There is an exhaust leak
dude i own a cali spec maxima which is no different than your 5th gen. I did a fed spec conversion to get rid of this code and the front precat. SO that means my car used to have a front pre cat that was not a part of the y pipe. Now it doesn't. The two downstream o2 sensors are now being simulated to do away with the P0430 code..
Old Nov 9, 2006 | 01:03 PM
why even convert a cali-spec to a fed-spec if you could have just used sims to get rid of SES light?
People, please lets stay on topic. I am looking to replace my precat and trying to find the cheapest way to do so. At this point, I do not want to use sims, even though it is less costly option.
Old Nov 9, 2006 | 02:46 PM
upstatemax's Avatar
I think your best/cheap bet is going to be a Sim...
Or get headers and a Sim.
Old Nov 9, 2006 | 05:45 PM
1FSTMAX's Avatar
i didnt do it to get rid of the ses light.. Have you phisically taken a look at the front precat? Have you taken the precat apart? If you have then you'll know what im talking about.
45 bucks shipped gets you a low milage pre cat off my 99..
Old Nov 9, 2006 | 06:21 PM
I have not taken a look @ front precat nor taken it apart...but have an idea of what it is.
My point is that that P0430 is the code for Bank 2 (front precat) and none of the 02 sensors, otherwise there would have been a different code.
I'm still debating on what should I do to fix this issue.
