Carbon Fiber Tutorials
Old Jan 14, 2007 | 01:21 PM
X-Vert's Avatar
Do you guys know where I can find some carbon fiber tutorials? I've searched on google, but I'm terrible at it so I really couldn't find squat except this...
http://www.350z-tech.com/zwiki/Tutor...on_Fiber_Layup
which really doesn't help me with what I wanna try. I just want to make a flat piece, about 1.5-2mm thick. If I was to to do that... would I need to wrap the cf material in something? I'm really aiming at just creating a flat sheet straight out of cf, not wrapped or anything.
Let me know... thanks.
Old Jan 14, 2007 | 01:30 PM
MrGone's Avatar
If you want a flat piece, use a flat surface
It's as simple as that
Old Jan 14, 2007 | 01:42 PM
X-Vert's Avatar
yea but wouldn't I need some thick cf sheets for that? or its just a matter of how much epoxy I apply? The cf cloth i'm looking at is .25mm thick.
Old Jan 16, 2007 | 11:27 AM
MrGone's Avatar
What are you trying to make?
Thickness... depends... but if it's purely cosmetic then you could just do one layer of carbon fiber and then a layer or two of fiber glass.
Also if you are making replacement parts, you should really create a mold first.
Old Jan 16, 2007 | 12:29 PM
bigEL's Avatar
Depending on how large of a piece you want, there are pre-made panels available in countless number of thicknesses, weaves, finishes, fibers, etc... If you just need a flat panel less than 3x3 ft., that's the way to go, especially if you have no experience. Controlling the conditions and getting the ratios right is a PITA. I remember laying up a racecar in grad school in the winter and the drafts from people coming/going caused the epoxy to gel up into lumps and that led to delamination and a catastrophic failure in competition.
Old Jan 16, 2007 | 09:26 PM
X-Vert's Avatar
http://img.villagephotos.com/p/2005-...ingshroud1.jpg
I wanna try making this myself, if I succeed... I wanna move onto making other small parts. It's just an idea i got flowing around my head and wanna try to see if I can do it.
Old Jan 17, 2007 | 11:52 AM
catabibazon's Avatar
Any good sites for this? I'm also looking for similar information.
Old Jan 17, 2007 | 12:15 PM
X-Vert's Avatar
I found this... http://www.mashie.org/guides/cfbalsa02.html but really doesn't help me.
Old Jan 17, 2007 | 11:37 PM
bigEL's Avatar
Try searching for diy/homebuilt ultralights or bikes or college projects. I've seen lots of good write-ups and tips. Suppliers sometimes have very good FAQs/hint/tip pages on their websites. Also, if you haven't already, try broadening your search to composites in general, rather that just carbon fiber. The same basic principles apply. Good luck.
Old Jan 18, 2007 | 08:01 AM
Flava_24/7's Avatar
Boosted Panda
I have a pice similiar to that, and it has FG underneath it with the CF layered on top.
On a peice that large, what would you plan on using to cut it so that ut maintains the perfectly straight lines?
Old Jan 18, 2007 | 11:59 AM
ChromeSE5's Avatar
Here is a forum for composite materials.
http://www.racingcomposites.net/
Old Jan 18, 2007 | 01:50 PM
AceofSpds's Avatar
wat
Here's another http://www.compositeforum.werksberg.com/
Old Jan 18, 2007 | 06:14 PM
SNOMAX's Avatar
PM me for LCA's!
Here's a very straightforward site. It might get you started, I've had it bookmarked for quite awhile:
http://www.webbikeworld.com/t2/carbo...orcycle-parts/
Old Jan 19, 2007 | 07:46 AM
nismo_star's Avatar
http://www.aircraftspruce.com/menus/cm/carbonfiber.html <--used to get material here until prices went sky high. I bought a few rolls of CF on ebay, and alot of resins, expoxy.
http://www.aircraftspruce.com/catalo...racticekit.php <--Get your practice kit here, and learn the right way to mix your epoxy and how to 'lay up' your composite work.
Old Jan 19, 2007 | 06:50 PM
bigEL's Avatar
Last time I visited, it was a great site in terms of navigation/interface, selection and info. I used to buy a lot from them too, until they screwed up one of my biggest orders. Double-charged me, claimed they sent my order (w/o tracking), but I never received anything. I had to fill out all these forms for a refund that they ultimately didn't grant. It held up my project for 4 months before I just found the stuff I needed locally. If Wicks aircraft is still around, they're a pretty comparable store, but last I heard, their prices were going up and their service was going down too.
KabirUTA13
19
Oct 17, 2015 02:15 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
BrandonCause
Sep 20, 2015 10:20 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
