what happens when
Old Apr 19, 2007 | 07:03 PM
chazmcgee's Avatar
what happens when
You put regular oil when you were previously using synthetic? I ask because i currently have regular in there because I just got it out the shop and I didn't have the time to change it today but i plan on it tommorow after school. Could I be damaging my engine right now?
Old Apr 19, 2007 | 07:21 PM
MrGone's Avatar
nope you're fine
Old Apr 19, 2007 | 07:22 PM
chazmcgee's Avatar
so its okay to change it tomorow but def. not a long term thing right?
Old Apr 20, 2007 | 06:38 AM
NismoMax80's Avatar
SuPeRmOd
your engine will absolutely, definitely not blow up
Old Apr 20, 2007 | 06:48 AM
xoomer.com's Avatar
I Donate! Why Don't You?
^^ LOL, what happens if the guy has problems reading. PANIC!
Old Apr 20, 2007 | 07:41 AM
4MySwee's Avatar
That's just wrong on all levels NismoMax80!
Old Apr 20, 2007 | 09:34 AM
Majestic Ken's Avatar
so it should be fine right if u were using that oil right? as long as the car starts u should be fine. if its 3k miles and you've been using synthetic u could go another 7 or 8 k??? but im sure u wouldnt do that
Old Apr 20, 2007 | 10:09 AM
NismoMax80's Avatar
SuPeRmOd
http://forums.maxima.org/forumdispla...aysprune=&f=70
a lot of info. both oils are compatible, but you should stick to one.
Old Apr 20, 2007 | 10:25 AM
MajesticBlueSE's Avatar
In my 944 the previous owner used dino oil and I started using the Mobil 1 stuff. The oil in Mobil 1 is thinner and will "seep" more into the seals/through and might cuase leaks. In my cause it did this on the 944 and I have to get new gaskets.
Old Apr 20, 2007 | 11:04 AM
xoomer.com's Avatar
Thats because your 944 was as old as dinosaurs are. New engines have gaskets/seals that are very compatibile with synthetic oils. If you have a leak already, synthetic will just make it more apparent.
Old Apr 20, 2007 | 11:39 AM
NismoMax80's Avatar
SuPeRmOd
no, your gaskets already needed replacing. the dino just build crud around the leaks hinding them. the mobil cleaned the crud away revealing your problem.
of course you could learn that by looking through the link i provided^^^^
Old Apr 20, 2007 | 09:32 PM
MorpheusZero's Avatar
you die.
