Hub centering rings, does one brand fit all?
Old May 18, 2007 | 06:29 AM
cardana24's Avatar
Blown
I currently have HP wheels with hub centering rings on my 98 maxima. I am switching to Axis wheels. The wheels I am buying do not come with centering rings. I am wondering if I can use the centering rings on my HP wheels on the Axis wheels or do I need to get a new centering ring since the center bores on the wheels may be different (I'm not sure if they are or not). If I need new ones does anyone know the best place to get some axis centering rings quickly? Thanks for any help.
Old May 18, 2007 | 10:21 PM
Lordrandall's Avatar
Make sure you check the centerbore of your new wheels. Pretty much any wheel or tuner shop should carry them.
Old May 19, 2007 | 10:26 PM
Project323
my ssrs have mille miglia center rings...
Old May 20, 2007 | 07:10 AM
max2moon17
one size should fit all, i know this because that is what the mechanic said that munted my rims.
Old May 21, 2007 | 05:46 AM
cardana24's Avatar
Blown
ok so it sounds like I can use the rings on my HPs. Next question is, should I just stick with the plastic ones that came with my HPs or would a metal ring be better and where would I buy those? There are really no "tuner" shops in the area so it would be something that I would probably need to get online. Thanks for the help.
Old May 22, 2007 | 09:25 PM
If your plastic rings are in good shape and fit correctly go ahead and use them. Replace any that are cracked or broken.
Check ebay first, then go to google.
Old May 23, 2007 | 05:32 AM
cardana24's Avatar
Blown
well if anyone else is wondering the samething I did. I finally figured it out. The center bore on my fourth gen is 66mm and the hub bore on the axis (I may add this is most wheels) is 73.1mm, so I needed a 66->73.1 hubcentric rings. I some metal rings yesterday on ebay from discount tire.
maxfever1987
Sep 6, 2015 06:20 PM
maximusrising
Sep 2, 2015 09:55 AM
