Ground Control Springs ?
Old Jul 15, 2001 | 07:07 PM
cRedrum's Avatar
I have a set of Eibach Prokits here, and while on the ****ter i was looking at my sport compact and i saw an ad for ground control springs. Are these springs any better than the Eibach pro kit, i know they are made by eibach. Would you reccomend them more than the Prokit ?
Old Jul 15, 2001 | 08:11 PM
Weasel's Avatar
Ground Control coilovers are Eibach springs in threaded sleeves that allow you to raise and lower the ride height. You need to provide your own shocks (preferably Koni).
Old Jul 15, 2001 | 08:12 PM
max'n out's Avatar
It's the same thing you just get a adjustable spring perch.
Old Jul 15, 2001 | 08:20 PM
Screaminfast's Avatar
I heard you can request your own Spring rate though. So, you could get high rate race springs.
Old Jul 15, 2001 | 08:28 PM
max'n out's Avatar
Ive never heard that. Though I may be wrong. That would take a long time to wait for and is not very cost effecent.
Old Jul 15, 2001 | 09:38 PM
Weasel's Avatar
Ask Kev about it, I'm pretty sure he requested custom spring rates.
Old Jul 15, 2001 | 10:19 PM
Nealoc187's Avatar
SLOW
It's only $40 more to get custom spring rates for GCs. As far as how they compare, the Pro-Kit is a progressive rate spring, whereas GCs use linear rate springs.
Old Jul 15, 2001 | 10:44 PM
Jane97SE's Avatar
Used force to obtain Admin powers
You can get custom springs from Ground Control. All you have to do is request them. It doesn't take any longer to get the springs and it doesn't cost more to get custom spring rates. When I ordered mine, they arrived the next day.
IMO, the handling is better than the Eibach Pro Kit.
Old Jul 15, 2001 | 10:53 PM
ohboiya's Avatar
what spring rate did u get? same as Kev's?
I think he mentioned that he didn't like his rear spring rate? too soft?
Old Jul 16, 2001 | 12:17 AM
pawn's Avatar
i would like to Gc's but have heard the ride is Harsh....now that ive heard you can request custom spring rates...could i get them to be more like the stock ride....if so what spring rate would that be?
Old Jul 16, 2001 | 07:20 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Hers:
450 front 7"
375 rear 7"
Mine:
500 front 6"
375 rear 6"
I wouldn't mind going with with 450 lbs for the rear
Old Jul 16, 2001 | 07:27 AM
ohboiya's Avatar
Hey Kev,
1. Is her set-up the "stock" set-up from GC?
2. Am I correct in my understanding that the 7" allows for more wheel gap than the 6"? If not .. what difference does the 1" make?
3. If u get the 450 for the rear ... wouldn't that make your ride even harsher?
tkx!
Originally posted by Y2KevSE
Hers:
450 front 7"
375 rear 7"
Mine:
500 front 6"
375 rear 6"
Old Jul 16, 2001 | 07:29 AM
Hers:
450 front 7"
375 rear 7"
Mine:
500 front 6"
375 rear 6"
Why not get 500 Front and Rear? Would that make handling better?
Thanks,
Mike
Old Jul 16, 2001 | 08:22 AM
Y2KevSE's Avatar
Originally posted by ohboiya
Hey Kev,
tkx!
1) Nope. I think they give you 8" springs for the front (or was is the rear).
2) Correct. 6" let's you drop the car even further... drop it too much and you'll bottom out all the time though. 1" makes quite a difference if you want a slammed look.
3) Yup.
Thanks,
Mike
The rear is lighter than the front, so I might be bouncing all over the place. 500/500 would give me more oversteer... could be good, could be bad.
Old Jul 16, 2001 | 08:46 AM
hmm, oversteer, FWD car + a little oversteer = amazing in Auto X...muahahahahh
Now, just to get the money. Not that I haven't already spent 7Gs on Maxi this summer already...(S/C, tranny, clutch, flywheel, rims...etc)
Ah well, Thanks for the info Kev.
Old Jul 16, 2001 | 09:28 AM
cRedrum's Avatar
So is the ride just the same as the pro kit or is it more harsh. I dont want a really harsh ride. What do you guys suggest ?
Old Jul 16, 2001 | 10:15 AM
Y2KevSE's Avatar
If you don't want a harsh ride, dont' get the GC's.
Old Jul 16, 2001 | 10:23 AM
ohboiya's Avatar
how harsh is "harsh"?
oh well ... 2 late!
Old Jul 16, 2001 | 01:09 PM
Y2KevSE's Avatar
oh well ... 2 late!
It's all relative. I don't consider my ride that harsh, but other's might have a different opinion. It's definitely harsher than the Eibach Pros.
Old Jul 16, 2001 | 01:14 PM
pawn's Avatar
i understand the fact that if i do get Gc's that the ride is going to be a little harsher..but if you can request custom springs....couldnt you get them to be a little more like the stock ride???? because i want the Slammed look...thats all i care about...i don't really do any auto xing or anything like that...i just want the look....
Old Jul 16, 2001 | 01:20 PM
Y2KevSE's Avatar
Soft spring rates with short springs equals spring bind...... basically, the springs will compress all the way, which is not good.
Sprint springs give you a 2" drop if you're interested in those.
Old Jul 16, 2001 | 02:39 PM
ohboiya's Avatar
How much wheel gap does Caroline have with her stock GC setup? or put another way ... how much did it lower the ride?
Old Jul 16, 2001 | 04:23 PM
max'n out's Avatar
It's adjustable once you put the sleeve on your choice of strut/shock
Old Jul 16, 2001 | 04:38 PM
Jane97SE's Avatar
Since you are addressing Kevin I'm assuming you are talking about me.
I have a little less than an inch of wheelgap.
BTW, my name is Jane
Old Jul 16, 2001 | 06:24 PM
ohboiya's Avatar
oh **** ... ... I was thinking about my hunny ... sorry Kev ... sorry JANE!!!
Old Jul 16, 2001 | 09:54 PM
Y2KevSE's Avatar
Doh!
Old Jul 17, 2001 | 05:47 PM
ohboiya's Avatar
Hey Kev/Jane ... how much did you car drop with your springs Kev? I asked the guy that I bought the GC's from with the 7" springs & he says that it'll drop from 1/2 to 1" at the most?
Old Jul 18, 2001 | 06:41 AM
Y2KevSE's Avatar
mingo and I compared my car to his and it was about 2" (I've dropped it further since then, probably about 0.5" more).
BkGreen97
Apr 2, 2016 05:47 AM
imported_Nismo_max
Feb 17, 2016 03:39 AM
Stagnet04
Sep 13, 2015 09:32 PM
