View Poll Results: Have you ever had SS brake lines fail on you?
Yes, i've had them fail on me
7.69%
No issues at all
24
92.31%
Voters: 26. You may not vote on this poll
Reliability of Stainless Steel Brake Lines
Old Sep 5, 2007 | 03:48 PM
soundmike's Avatar
Very sound, Mike
If you have SS brake lines in your Max, will you kindly provide input on how long you've had it and whether or not you've had problems with them?
Thanks!
Old Sep 5, 2007 | 05:04 PM
!PrjctMax!'s Avatar
I think I've had them for about 8 months now. They went through one Chicago winter...and no issues! knock on wood!
Old Sep 5, 2007 | 05:13 PM
JPIZZLE's Avatar
I had them on my 2000 Maxima and a little afer a year my right rear blew out on me . Unfortunatley I had my girl with me and no pressure on my brake pedal. Luckily i was only in a parking lot and I down shifted till the car was in a safe place on th e parking lot!
Old Sep 5, 2007 | 05:30 PM
!PrjctMax!'s Avatar
tis why I check my fluid all the time, even though I know the actual line can go bye bye any time! could be
Old Sep 5, 2007 | 05:37 PM
MacGarnicle's Avatar
Next time I change pads and rotors, I was thinking of swapping to SS lines - unfortunately, I've heard lots of stories of the lines breaking, leading me to doubt their reliability and safety. Anyone else have any thoughts on this?
Old Sep 5, 2007 | 06:49 PM
!PrjctMax!'s Avatar
IMO, just make sure that they are made specifically for your car and just check on them time to time. Also, make sure to tighten them properly, but obviously not too tight as that may cause leakage.
.02
Old Sep 5, 2007 | 08:45 PM
zero2sixtyZ's Avatar
You embarrass me.
I have had them for over a year now, no problems whatsoever. I didn't even know there was a known issue? Time to search I guess.
Old Sep 5, 2007 | 08:49 PM
Matt93SE's Avatar
STFU n00b!
I've had several sets on several cars for several years. i.e. the rear ones on my Maxima are probably 8 years old now. I switched to a custom front brake setup about 5 years ago and I'm still using those lines too.
The big problem people run into with these- especially on the rear of the 4th and 5th gens is that the hydraulic brake lines rub against the rear suspension. if you have any place where the lines are rubbing, you MUST insulate the lines with rubber hose or fasten the lines to the part so they don't move against it. if it rubs, it will eventually wear a hole in it.
the big issue is common sense and proper installation. without both of those, you can botch even the best products in the world.
Old Sep 5, 2007 | 09:06 PM
z32drifter's Avatar
I don't have SS hoses on the Maxima, but the Z has had a set since 2001 with no problems.
Old Sep 6, 2007 | 08:59 AM
mtrai760's Avatar
'Trynna' is not a word
Stainless lines are not a set it and forget it item. They should be checked regularly for any signs of wear. If your not willing/able to do this, you should not install stainless steel lines, stick with stock. I check mine everytime I do an oil change, and make sure nothing is rubbing. Over 2 years on the current set with no issues.
Old Sep 8, 2007 | 10:16 AM
RLW001's Avatar
My Techna-Fit lines use the OEM Clips and mount just like OEM lines. No rubbing issues or zip ties on my install.
Old Sep 9, 2007 | 08:40 AM
djfrestyl's Avatar
Suspension Yoda
I've had mine on for about 25K miles, almost a year. No issues, but I do check them periodically. I've got Goodridge's and they have all the OEM clips as well.
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
