GTECH Run >>>
Old Aug 20, 2000 | 10:16 PM
ZuMBLe's Avatar
My latest GTECH run tonight..
70 Degrees
15.29@94.8mph
My last run was at about the same temp but I ran a 15.39. I think I got a really bad launch this time.. The additional torque from the Y-pipe makes me spin tire and torque steer.. Will run again after I learn how to control the car better.. I don't want to lower the tire pressure because thats not "real world" scenario... But Y-pipe dropped my 1/4 mile time by .1 even though I had a really bad tire spinning launch.. I would say the pipe did something.. =)
ZuM
Old Aug 20, 2000 | 10:56 PM
SeaMAX's Avatar
Doesn't the Y-pipe decrease low end (torque)...
but increases high end (hp)? This is the case when I got my custom y-pipe installed. But I also got a PR CAI to compliment it. My $0.02.
Old Aug 20, 2000 | 11:10 PM
Nismo87SE's Avatar
Actually what difference does it make if the tires are a few psi lower? All though you don't want to ride on 22psi in the fronts it can help your launch. Also the Y pipe increases power from idle to rev limiter, you shouldn't lose any power anywhere. Too bad I'm stuck with stock manifolds
Old Aug 20, 2000 | 11:12 PM
ZuMBLe's Avatar
No way...
I have a lot more torque all over the place.. I think I can actually launch the car without brake torque now. It pulls hard all over.
ZuM
Old Aug 20, 2000 | 11:16 PM
ZuMBLe's Avatar
Well I want to run the same pressure as I would when my car is normally running around on the street.. For those stoplight races.. =) I want to keep it as real as possible.. I don't want to run 30psi.. because I don't run 30PSI.. At a stoplight race I can't run out of my car and break out the pressure gauge and lower the pressure.. hehe.. =P
ZuM
Old Aug 21, 2000 | 12:29 AM
Chebosto's Avatar
RIceD OuT moDErAtor
Ohhh. TIRE pressure..
i thought you were talking about BOOST.. i was like GAWD DAMN! 30 pounds of boost on a 4th Gen.. sheeeit!!!! ahah
that was a good laugh.
Old Aug 21, 2000 | 12:51 AM
ZuMBLe's Avatar
No, my watermelon sized turbo!!! =) >>>
30lbs of boost and only running a 15.2?? Hehe.. I must have spun the tires to the end of 1/4 mile then..with the floor wet.. hahaha.. Yes tire pressure.. =P
captchaos
Mar 15, 2016 12:18 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
cruce91
Sep 20, 2015 10:23 AM
ballerchris510
Sep 10, 2015 09:35 PM
