Cure for Automatic Jerks!?!
Old Jul 26, 2001 | 11:49 AM
BIGMAX's Avatar
I know several people had problems with their auto trannys jerking when they let off the gas at around 45-50 MPH.
I of course had the same problem.
I got my belts replaced today at 80,xxx for the first time and the jerkiness has gone away and the the whole drivetrane feels tighter now.
Don't know if this will work for everybody.
Just thought I'd share.
Old Jul 26, 2001 | 08:27 PM
BIGMAX's Avatar
Drove around some more tonight and still no jerking.
Problem solved.
Just thought I'd post again to move this thread back to the top so everyone can view it.
Old Jul 26, 2001 | 10:15 PM
Eric L.'s Avatar
I'm not quite sure I see the relation. What do the drivebelts have to do with a jerky transmission? Glad your problem is gone though.
Old Jul 26, 2001 | 10:25 PM
Sonic's Avatar
Doing a complete tranny fluid flush using the 'Magic Sucker Pump' as DBM likes to call it, also works well. I'm with Eric in saying that the accessory belts shouldn't have an effect on your transmission.
Old Jul 27, 2001 | 01:00 AM
Eric L.'s Avatar
If you shop around, you can usually get a T-tech service for the same price as the sucker pump. The T-tech machine hooks up to the transmission cooler line and replaces all the fluid in around 15 minutes, better than the sucker system which only pulls fluid out of the dipstick tube.
Old Jul 27, 2001 | 04:04 AM
Sonic's Avatar
Cool, I didn't know that.
Old Jul 27, 2001 | 07:26 AM
Lime's Avatar
T tech like valvoline service? I have to get this done as soon as I can...my ATM is blech, and I want to switch to synth.
Old Jul 27, 2001 | 07:46 AM
BIGMAX's Avatar
I don't know how new belts fixed the problem either.
But it did, and I'm glad.
Old Jul 27, 2001 | 09:57 AM
Frezny's Avatar
just a theory
Think of worn belts like a lose bicycle chain. They've both lost some tension. When you let off the throttle, you go from lets say a "normal" rate of revolutoin, to a "higher" rate of revolution, thus demanding more traction from the belt. Maybe the jerking is caused by a warn belt instantaniously getting traction and snapping taught again? Or, in some way or the other I'm manifesting my desire to be a kid again...
Old Jul 27, 2001 | 01:51 PM
SuDZ's Avatar
T Tech service
I seen you talking about getting the T Tech done. How much does it generally cost I know around me at Jiffy loop it is around 70 - 80 dollars or so. Also if I wanted them to put in something like Redline fluid are they able to or is it like when they do oil it comes from the ceilings storage area for fluids?
SuDZ
Old Jul 27, 2001 | 05:16 PM
Eric L.'s Avatar
Re: T Tech service
SuDZ
T-tech is normally $90-100. I brought in my own Redline fluid, 12 quarts, and they took $10 off the cost. REdline oil is very expensive though.
MaxStock
Dec 5, 2016 05:19 PM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
