OSCAI users beware...READ THIS
Old Jul 30, 2001 | 06:16 PM
mzmtg's Avatar
Minister of Silly Walks
I decided it was about time I cleaned my K&N panel filter since I hadn't done it in a while. I was shocked at the amount of $hit stuck in it. I literally got a little pile of dirt and sand and bugs when I tapped it on the cement.
My OSCAI has a forward facing scoop on the bottom and I don't remember driving through any swamps...
So just watch out and clean or change your filter often with this setup.
Old Jul 30, 2001 | 06:26 PM
UMD_MaxSE's Avatar
Got Bent?
yup.... i have about 5k miles on my K&N with the same setup and it has some crap in it. I knock out all the extra bugs and crap out of my filter often though. But, if you do have such a setup, cleaning the filter more often would be wise
Old Jul 30, 2001 | 08:15 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Hey i have an engineering question for you. what do you think about bridging the signal from BOTH downpipe O2 sensors to get a more accurate reading. my a/f guage is not very accurate, like everyone else's. i'll try anything to get this to work.
Old Jul 30, 2001 | 10:32 PM
y2kse's Avatar
I don't seem to have that problem. But then again I keep the OSCAI tube tucked inside the splash guard. That probably explains it.
Old Jul 31, 2001 | 05:18 AM
mzmtg's Avatar
Hmmm, if you hooked the sensors up in parallel to the guage, that would work. But I dont see any reason it would be more accurate. The most accurate way to do it is to install a seperate wide-band lambda sensor and not rely on the narrow-band factory units.
Old Jul 31, 2001 | 05:27 AM
me and confused were talking about it at maxus, we felt that if you had a signal from EACH bank of the engine it might be more accurate, different cyclinders act different. So all you would have to do it tap the other one and get a Y, 2 to 1, connector and bling bling. Wouldn't the voltage be too high?? I thought you would need a 1/2 reducer or something, i'm just guessing now. that's why i asked the engineering man.
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
JonBlz
Oct 5, 2015 06:02 PM
