I30 Kickplate installation
Old Oct 22, 2000 | 12:47 PM
VQracer's Avatar
I was reading this on the maxima.org webpage here
https://maxima.org/shoptalk/sub_modi...t4/index.shtml
and was wondering what is a door panel trim remover
Old Oct 22, 2000 | 02:16 PM
Whitemax's Avatar
Disco Biscuit
it's a forkshaped tool
with 2 flat fingers. You slip it under the panel, with the plastic grommet thatholds the panel on between the fingers and pry it up. Crtuchfeild sells them for like $2.50.
Old Oct 22, 2000 | 05:13 PM
JULIAN's Avatar
You don't need the tool >>>>>>
I just installed mine today and all I did was use my fingers to pry it off, it DID NOT do any damage and changing it all out to the new ones, took less than 5 minutes for all 4. I also waxed the area underneath before putting the new ones on. They are very easy to POP off, try it yourself.
Old Oct 22, 2000 | 05:55 PM
VQracer's Avatar
okie dokie!
Old Jul 26, 2001 | 06:30 PM
bert's Avatar
I concur, you can easily pull them off with your hands. Pick one side and pull.
I was worried that I would spend hours getting the old ones off, took me 2 minutes.
One thing that I would recomend is that you pull the protective cover left to right and pull slowly. You will need a small picking tool to get some of the covering out. A surgical pick would do fine.
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
