Motor Swap Update Day One 8/1
Old Aug 2, 2001 | 01:42 PM
MardiGrasMax's Avatar
I started the removal of the factory motor & trans lastnight. I started by doing a compression test on the factory motor, all cylinders were above 200psi with a difference of less than 10psi. Ive completly unhooked the wire harness from the factory motor (what a tedious freakin job), removed the battery and tray, upper CAI plumbing, disconnected the fuel lines, EVAP line, vacuum booster line, throttle & cruise cables and evacuated the AC. And transfered some parts to the new motor.
Tonight I'm going to some of the under car things and get the fluids out, etc.
My goal is to be ready to hoist by Saturday AM and ultimatly have the new motor running by Sunday night. With any luck its do-able, but with a project like this theirs always unforseen problems to over come. Sinewave has been kind enough to offer to help me Saturday and Sunday and he has lined up some of the speciality tools I need like the shop crane. THANKS KEITH YOU ARE THE MAN!!!
Wish us luck!!!
There are some pics on my home page too.
Some history on this...
As some of you may know in June of 2001 I purchased a used motor, transmission and Stillen/Vortech V1 Super Charger from Steve Sze of Carative in Philadelphia PA. Steve gave me a very good deal. The motor was constructed by IMPO Performance. IMPO verified what was done to the motor. It was bored 0.020" over. It has oversized stock pistons that have been coated for heat resistance. Shot peened factory rods and crank. The entire rotating assembly was dynamically balanced. The fuel injectors were also cleaned and balanced by IMPO. The heads are stock but with a fresh valve job.
IMPO claims that this motor will take 6psi of boost and a 125hp Pro-Fogger shot of nitrous with a few degrees of ignition timing retard. So IMPO thinks this motor hold ~400 hp at the crank, we shall see! My approach will be more boost and less nitrous. I've installed the 3.25" upgrade pulley from Vortech which should be good for ~10spi. I cant make up my mind which way to go with the nitrous, dry or wet. But with boosting at 10psi I don't think more than a 75hp shot is needed, its really just an intercooler in a bottle. Yes I know I'm pushing the motor and could very well blow it up, but that's half the fun and I've still got my stock motor to fall back on.
The transmission I got from Steve has a lighted factory flywheel and a Centerforce Dual Friction clutch upgrade. So I think its up for some abuse too. Just as with the motor, I've got my stock transmission to fall back on.
IMPO recommends that the motor be broken in for 2500 miles before I do any sever duty racing. According to Steve the motor had only ~600 when he totaled his Maxima, IMPO verified this too. So by October or so I should be ready for the track. I'm hopping for mid to low 12 second ET's, that may be a bit optimistic but you got to have goals!!!
Old Aug 2, 2001 | 01:49 PM
RICOiz704's Avatar
Sounds like a monster in the making...keep up the good work
Old Aug 2, 2001 | 01:52 PM
theblue's Avatar
So cool! sounds like a lot of fun... good luck and keep us posted. You PMed me for the info on my gauges. I got them done by a place here in Rochester NY called the install shop. The guy who did them is called Chad and I'm the second maxima he has done this on. Their number is (716) 292-1772
Jeff92se's Avatar
I'm needing a caw
Go luck bro! Be safe. Change the oil/filter on the new engine before starting it again.
Old Aug 2, 2001 | 01:59 PM
emax02's Avatar
Sounds like like a lot of work! But a lot of fun too..
Good luck with it all and keep us up to date.
Old Aug 2, 2001 | 02:07 PM
SmoothMax's Avatar
OG
Looks like you're gonna have your hands full for a while. Good luck man and keep up the good work.
Old Aug 2, 2001 | 02:30 PM
mtrai760's Avatar
'Trynna' is not a word
Good Luck!!!
Old Aug 2, 2001 | 02:35 PM
Synki's Avatar
Good luck wiht the motor.
I would love to come up but i have been busy with some things.
Old Aug 2, 2001 | 02:43 PM
Oh yea!!! Im gonna run dino oil till 2500 miles (IMPO's recomendation). I plan on changing it at least three times. Perhaps after the first 25 miles or so because of fears of build contaminants and dirt from shipping etc., then after 500 more miles and then again after another 1400 to synthetic.
Old Aug 2, 2001 | 04:19 PM
Screaminfast's Avatar
And I was this so called first maxima.... Chad is my good friend...He actually gives me a lot of good deals. I am goin home to Rochester to have my FP guage installed by him in the cigarette lighter place....Let me know if you have any questions Matt....
-Mike
Old Aug 2, 2001 | 04:51 PM
deezo's Avatar
Do it up man, do it up!
Old Aug 2, 2001 | 04:52 PM
theblue's Avatar
-Mike
I'm a little upset with the job they did on my body kit... its falling off all over the place... the front lip is currently being held on with duct tape because their screws fell out !?!? but my gauges are perfect!
Old Aug 2, 2001 | 05:19 PM
ejj's Avatar
ejj
And ya' know, until last night at the track when you got it out, I didn't even know they made black duct tape!
Old Aug 2, 2001 | 05:54 PM
theblue's Avatar
you mean "superblack" duct tape ;D
Old Aug 2, 2001 | 05:59 PM
Sonic's Avatar
Oh crap, that's ME!!
Old Aug 2, 2001 | 07:13 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Good luck Matt!
Old Aug 2, 2001 | 07:58 PM
Love the sig picture Blue, thats clasic!
I'm taking a break, I forgot how much gear oil stinks!!!
Old Aug 2, 2001 | 08:53 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
mmm, gear oil. and ya that picture was funny, medic was a little mad at me. but it's all good, it's good fun. courtesy of chebosto.
Old Aug 3, 2001 | 02:22 AM
deezo's Avatar
Nice pic Aaron.
Old Aug 3, 2001 | 04:38 AM
deezo's Avatar
Good idea. When I swapped the motor out of my truck, I ran it for 500 miles and drained the oil. But your idea is even better and will keep the engine clean of debris from the parts breaking in.
Old Aug 3, 2001 | 04:45 AM
mmmmmmm, i wonder how much it would cost to have this done. nos and s/c, droollll..........
Old Aug 3, 2001 | 04:47 AM
deezo's Avatar
Your life!
Old Aug 3, 2001 | 04:59 AM
Originally posted by deezo
Your life!
ya your right, i need to get some better brakes first.
Old Aug 3, 2001 | 06:50 AM
Vinipux's Avatar
holy $hit man, good luck with that swap, hope everything goes well, you might have the fastest maxima in here, good luck
Old Aug 3, 2001 | 09:40 AM
Sonic's Avatar
Ok back on topic, what happened on Day 2(yesterday)? Any progress?
Old Aug 3, 2001 | 09:46 AM
ejj's Avatar
ejj
http://forums.maxima.org/showthread....threadid=56525
Old Aug 3, 2001 | 10:20 AM
Sonic's Avatar
Oops.
Finkle
Sep 27, 2015 09:53 PM
MaxLife17
Sep 8, 2015 02:36 PM
maximusrising
Sep 2, 2015 09:55 AM
ffcbairn
Aug 16, 2015 09:29 PM
