Motor Swap Update, Day 5
Old Aug 5, 2001 | 07:49 PM
MardiGrasMax's Avatar
The good news...
The motor/tranney/SC is 100% in and ready to fire up.
The bad news...
It didnt fire but once or twice. Apparently the crank shaft position sensor for a 96 is different than that of a 98, go figure. I had my 98 in the 96 motor when we trid to fire it up. It didnt hit, we pulled a plug and grounded it and got one spark from 15 seconds of cranking, WTF? So we brainstormed and decided that is was the crank shaft position sensor. They are visually different. When I swapped the sensors we got good spark but it still would not start because the motor was flooded AND to top that off I had put a cap full of oil in each cylinder a few weeks back when I did some out of the car compression tests, so the plugs were quite fouled. I pulled the plugs and cleaned them and am leaving the car to sit over night to let all the fuel evaporate out of the cylinders and exhaust. I'm hopping it will hit tomorrow night, I'm gonna get some starting fluid just incase the oil in the cylinders is still a problem. Any other sugestions are appreciated.
Sorry no new pictures, I'm just freakin dead tired!
Old Aug 5, 2001 | 07:53 PM
Ironlord's Avatar
Hey man, great job! and you didn't expect this to just go perfectly did ya? Anyway, its awesome you're doign this and i wish you the best of luck tomorrow.
Old Aug 5, 2001 | 08:14 PM
emax02's Avatar
Ahh, the suspense must be driving you crazy! Or maybe your so damn tired you don't even want to think about it . If it was me I whould be out there cranking it every 2 minutes, lol. As always good luck dude!
Old Aug 5, 2001 | 08:59 PM
theblue's Avatar
you're not going to get any sleep tonight knowing what you'll get when you wake up... hope your problems are minor and solved - I see the number 12 in your future
Old Aug 5, 2001 | 09:12 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
ya i definetly would not be getting any sleep at all tonight. that much power just lurking outside waiting for you. i'd be out there with a fan blowing the gas out.
Old Aug 5, 2001 | 09:55 PM
Jeff92se's Avatar
I'm needing a caw
So did the engine come out of the top okay??
Good luck man!
Old Aug 6, 2001 | 02:42 AM
mtrai760's Avatar
'Trynna' is not a word
Your cars gonna be sooo freakin fast! Good luck.
Old Aug 6, 2001 | 03:11 AM
mingo's Avatar
stand clear of the tail pipe you might blow out fire during the initial start up..(i think)
Old Aug 6, 2001 | 07:15 AM
Emax, your right about being so darn tired that I blew it off for the night. But I would be able to sleep if I wasent so sore. It blows when you wake up every hour or so because your so sore you have to change positions, it is what it is though!
Jeff, After we dropped the tranney from the bottom, the motor hoist out the top was a piece of cake!
I'll play with it tonight when I get home from work. It should be un-flooded and I'll hit it with some starting fluid.
Do you think its ok to sprak the starting fluid through the supercharger and into the pipeing with the MAF sensor and all, or should I spray it through a vacuum hose?
Old Aug 6, 2001 | 07:41 AM
infinitiblast's Avatar
No dont spray that starting fluid thru your supercharger. Whew dont wanna burn up a good maf sensor either. I presume that you have installed an aftermarket fuel pump. I say turn the key to the on position let it sit there for oh say 30sec let that fuel pump get those lines full of good fuel. Then dont dare touch that gas pedal. Try it then after installing an engine in one of my toyotas I had to leave the key on for like 30 sec before it feed good fuel to the engine. Now you say it was flooded but are you sure. Check all those fuel connections and the what nots. Well thats just an idea
Old Aug 6, 2001 | 07:44 AM
gLok's Avatar
I give anyone respect for doing what you did.
TRUE DIY RULES!
Good luck, its gonna be a screamer.
Old Aug 6, 2001 | 08:28 AM
Ive got good FP the gauge showed ~33psi, not to mention the gas smell comming out of the exhaust and the plugs reaked of gas, I'm sure it was flooded. We cranked it over for a sum total of ~5min on different ocasions with the wrong crank position sensor installed.
I guess I'll find a way to spray starting fluid through a vacuum line or somthing if it still dosent crank by its self.
Old Aug 6, 2001 | 08:37 AM
Synki's Avatar
Good job Matt. Im sure you will find the problem. Gotta love Murphy's Law.
Old Aug 6, 2001 | 05:13 PM
ya murphy is the man, i say we kill him.
Old Aug 6, 2001 | 08:13 PM
It still wont start...
I tried it again tonight and it would not hit. It would bairly stumble. I pulled the plugs and 3 are sooty and 3 are clean. I feel that one of the 3 timing sensors, REF, POS or CAM is some how not working properly. After looking at the FSM I have some targets to attack.
Check all the grounds.
Check all 3 sensors for propper readings.
Check all 3 sensors harness connectors.
I know that.
Fuel pressure is good.
Compression is good.
So it most probably is an electrical issue effecting either ignition timing or fuel injector timing.
Are their any known differences between 96 and 98 engine controll sensors?
Any helpfull input will be appreciated!
Now to get some rest.
Old Aug 7, 2001 | 10:30 AM
Jeff92se's Avatar
I'm needing a caw
Re: It still wont start...
3 plugs: All from the same bank I assume ie.. front/rear bank?
Check to see that the fuel rail is not bent(ie.. crimped) The VE maxima has a solid fuel rail but to get to the front bank to the rear, it uses a rubber hose to cross over. Maybe that one is clogged/crimped/etc..???
Oh maybe the front / rear 3 plugs aren't firing for some reason? The direction for checking the grounds etc. is sound. Let me know what happens.
Since the VQ should have these sensors, they take readings off the crank but uses that info for ALL 6 cylinders correct? So I don't see how just 3 out of the 6 could be affected by ie.. CAS sensor.
If the 3 bad plugs come from the front AND rear banks, then something is definately fishy. I would have to think about that one.
I know that.
Old Aug 7, 2001 | 01:10 PM
Re: Re: It still wont start...
Thats what I got, 2 in the back and one in the front are sooty. Thats what leads me to believe its one of the timing sensors. I'm gonna hook it up to the OBD2 scan tool tonight to see it their are codes pending, perhaps I will gain some insight then.
Old Aug 7, 2001 | 01:15 PM
damn, this sucks, nothing can ever be easy.
Old Aug 7, 2001 | 01:37 PM
dwapenyi's Avatar
Bring that VQ to Life!
Got me sitting here with popcorn waiting with anticipation. Can't wait till the moment you come back and say
". . . . .and the beast awakens"
DW
Old Aug 7, 2001 | 05:02 PM
MR_Maxi's Avatar
Re: Bring that VQ to Life!
I'm waiting here 10,000 km away for the news, If all goes well i may follow your lead. Though I'm thinking of using VQ30Det pistons and more boost, anyway best of luck man, waiting fo the good news.
Finkle
Sep 27, 2015 09:53 PM
MaxLife17
Sep 8, 2015 02:36 PM
maximusrising
Sep 2, 2015 09:55 AM
ffcbairn
Aug 16, 2015 09:29 PM
