KNOCK Sensor >>>>>
Old Oct 23, 2000 | 08:34 AM
JULIAN's Avatar
How hard is it to replace the Kock Sensor on the 4th generation Maxima, has anyone done it before ???? What tools are needed, how long did it take and how much is a Knock Sensor. Thanks for any info.
Old Oct 23, 2000 | 11:05 AM
Matt_P
How did you know you needed one?
Is it knocking, but not cutting fuel for retarding the timing?
Matt P.
Old Oct 23, 2000 | 11:20 AM
Jeff92se's Avatar
I'm needing a caw
If it's in the same place as a VE30DE
It's one large pain in the ***. You'd better be pretty sure that's the problem before having to take your upper and lower intake manifolds off to get to it. Or I hope Nissan relocated it for the VQ30 engines.
Old Oct 23, 2000 | 12:00 PM
JULIAN's Avatar
I am getting a code 34 >>>>
which means the Knock sensor is bad. I can see the knock sensor under the intake manifold and may be even able to get to it without removing the intake manifold. It is held on to the block with a single bolt. I have to find someone with smaller hands to see if they can reach it. The dealer says $65 for the labor to replace it, but I am to cheap to pay them to do it. The knock sensor from Courtesy is $125 with the discount. Also one of the front O2 sensors went bad have to get that replaced too, $65 from Courtesy.
Old Oct 23, 2000 | 12:22 PM
JimW
Did you get the car wet??--->
I had the same problem also. It was silly of me, but I drove the car thru some standing water (only about 5") and all seemed fine. Then when I started the car up, I got the check engine lite. I checked the codes and I got a code for the knock sensor and the front O2 sensor.
I seem to remember the shop manuual saying that a knock sensor code doesn't mean that the sensor has failed, but just that it had detected knock. Can't remember for sure, but since you've got the manual, I'm sure you read it carefully.
In my case, I just kept resetting the ECU every 2 starts of the car, and on the second day everything had dried out and all was fine.
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
