FTSB question
Old Aug 14, 2001 | 07:25 PM
black019's Avatar
Hey everyone, I just installed my ftsb and I had a quick question. How can you tell if you over tighten the nuts or not? I know that they were a b!tch to loosen at first so I did tighten them back pretty hard. Anyone know a way to see if they are over tightened aside from taking a hard right and seeing if the bolts rip off?
Old Aug 14, 2001 | 07:29 PM
emax02's Avatar
Use a Torque wrench, you can by cheap yet descent TQ wrenche at pepboys,autozone etc for like $20. Chances are you over tightened the bolts, I did the same thing you describe and was later horrified that the bolts were Tourqed to 80 lb's! I believe the correct TQ is 40 lbs.
Old Aug 14, 2001 | 07:30 PM
clee130's Avatar
Go rent a torque wrench. AutoZone/PepBoys/R&S Strauss ... auto parts stores usually have a rent-a-tool program.
Give them a deposit, borrow the tool, use it, return it and get your deposit back.
Torque it to 35-40 ft/lb.
dmontzsta's Avatar
Ford Only.
You should of torqued them down.I dont know the spec check www.maximadriver.com for the install inst. and it will tell you what to torque them too.That is where I got my directions.
Old Aug 14, 2001 | 07:40 PM
black019's Avatar
torque wrench, thanks guys
Old Aug 14, 2001 | 07:56 PM
black019's Avatar
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
