what are coilovers????
Old Oct 24, 2000 | 06:01 PM
tunedup's Avatar
plz explain this
and what is the benefit of havin such
Old Oct 24, 2000 | 06:14 PM
Supa Lao's Avatar
I think the benefit is so that you can adjust the height of the car. There's probably more, but I can't think of more.
Old Oct 24, 2000 | 06:17 PM
CKNY's Avatar
well yeah, basically instead of putting fixed springs like eibach or h&r which give you a fixed drop of say, 1.5", you can buy coilovers (either ground control ~$400 or cattman~$1500). The coilovers let you drop the car as much as you want. The advantages are obvious. The difference between the cattman and GC coilovers are that the GC are just the coilovers - you have to get your own shocks (and to be honest - no good shocks are out for the max right now... koni's are the best but they're a ***** to install). cattmans coilover system includes its own great shocks (kyb i think). If you have the money - cattman is the way to go.
Chris
Old Oct 24, 2000 | 06:21 PM
sleeper's Avatar
check..
out this website for coilovers, http://www.cattman.com
Old Oct 24, 2000 | 07:02 PM
brianw's Avatar
Coilovers are literally a racing suspension. A proper, complete coilover set has: camber plates, adjustable shocks, adjustable spring perches, replacement bump stops and interchangable springs.
They can be height adjusted using the spring perches which can go up and down on the body of the shock. Interchangeable springs are what they sound like- they are usually a 2.5" diameter spring available from numerous companies in various lengths and spring rates so the best one for your application can be found. Camber plates allow the alignment of your car to be adjusted as needed.
Everything is designed to work together, so your shocks can handle the spring rates used (usually much higher than stock, which is why using stock shocks with coilovers that allow such use is a BAD idea) and proper spring rates can be sold with the coilovers.
(e.g.: Cattman coilovers are usually sold with 375lb springs. This is roughly TRIPLE the stock spring rate. Stock shocks or even moderately stiffer replacements such as Tokico blues will die ugly deaths while shaking your butt around like crazy because they were mean to handle ~100lb spring rates, not 375lb!)
This is a very, very basic explaination. Sport Compact Car magazine has an article than explains more. I'd also check http://www.truechoice.com -- they sell coilovers and should have a guide somewhere.
Old Oct 25, 2000 | 07:31 PM
maxmiata's Avatar
I can't speak to the benefits of coilovers, but I can say there is a choice besides the Koni shocks-Tokico. I have Tokicos on my 95 Max and they made a huge difference on my car.
BkGreen97
Apr 2, 2016 05:47 AM
NewMax03
Oct 7, 2015 08:27 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Garrettz459
Sep 28, 2015 02:50 PM
