Pioneerelectronics.com Great Customer Support
Old Aug 21, 2001 | 10:38 AM
MegaMax's Avatar
Someone posted. Ground Control does as well... I thought I'd inform everyone that I had to contact them on a older Head Unit I had at home DEH-P7400. Anyway It was not listed on the site to I e-mailed them and what do ya know I got a reply...
If anyone has an older Pioneer radio here is the wire color codes...!
Before 1999 - Low Power Car Stereo KE models only.
GREEN - left front positive
GREEN WITH RED STRIPE - left rear positive
GRAY - right front positive
GRAY WITH RED STRIPE - right rear positive
BLACK - negative for all speakers
RED - switched power
ORANGE - constant power
BLUE - trigger for amp or power antenna
YELLOW = to lighting switch terminal.
Then connect a ground wire from the center post on the back of the radio, to
chassis ground.
Before 1999 - High Power Car Stereos DEH & KEH Models only.
GREEN is the left front ( + ).
GREEN/BLACK is the negative ( - ).
GREEN/RED is the left rear ( + ).
BLACK/GREEN is the negative ( - ).
GRAY is the right front ( + ).
GRAY/BLACK is right front negative. ( - ).
GRAY/RED is right Rear Positive ( + ).
BLACK/GRAYis the right rear negative ( - ).
RED is the Acc lead.
ORANGE is for memory.
BLACK is ground. ( - ).
BLUE is for power Ant.
YELLOW is to lighting switch terminal.
1999 Models - DEH & DEHP , KEH & KEHP
WHITE = left front speaker positive
WHITE/BLACK = left front speaker negative
GREEN = left rear speaker positive
GREEN/BLACK = left rear speaker negative
GREY = right front speaker positive
GREY/BLACK = right front speaker negative
VIOLET = right rear speaker positive
VIOLET/BLACK = right rear speaker negative
YELLOW = to terminal always supplied with power
RED = to terminal controlled by ignition switch
BLACK = chassis ground
BLUE/WHITE = to system control of power amp or power antenna
ORANGE = to lighting switch terminal.
DFS Alarm:
WHITE - Door Trigger - +/-
BROWN - Pulsed Output - + (500ma max.)
DFS Alarm +
WHITE - Door Trigger - +/- Input
WHITE/ORANGE - Remote Disarm - (+/-) Input
BLUE/BROWN - Starter Disable - (+) Output (500ma.)
WHITE/RED - Auxiliary Trigger - (-) Input
BROWN - Switchable Pulse/Constant Output - (+) Output (500ma.)
Mar 12, 2020 12:06 AM
kmitchel
Oct 30, 2015 10:12 AM
Hdnseek
Sep 9, 2015 05:55 AM
carid
Sep 9, 2015 05:06 AM
Maxboy23
Sep 4, 2015 06:04 PM
