Maxima 6sp vs. Altima 5sp
Old Oct 6, 2001 | 10:38 AM
wolfmanjack210's Avatar
Well the debate still rages on about which car will be quicker from 0-60mph and in the 1/4 mile and we'll never quite know the truth until two of these cars go head to head against each other in stock trim. However, given the technical spec's I've seen, I'm convinced the 2002 Maxima 6sp is going to kick ***. Of course I'm biased, given that I'll be getting the 6sp soon.
Let's look at the specs. Have a look at the spread sheet of numbers I've copied over from the 2002 Maxima and Altima Spec's sheet I obtained from my local dealer in Brampton, Ontario, Canada.
Quite clearly the Maxima gear ratios should yield better acceleration. Many people have stated that 6th gear is only an overdrive gear and that's the only difference between the two cars. It's clear that the addition of the sixth gear has allowed engineers to space the gear ratios closer together on the Maxima.
Furthermore, there is the issue of an additional 15 hp for the Maxima. Of course I've heard people argue that the Maxima weighs 200 lbs. more. From the literature I've reviewed this is not true. The Maxima is only 46 lbs. heavier. From my motorcycle racing days I was told that approximately 7lbs of extra static weight is equivalent to about 1 hp. That means the Altima would gain about 6.5 hp due to its weight advantage. That still leaves the Maxima with about an 8.5 hp advantage over the Altima thanks to its variable capacity muffler.
Given two equal drivers, I believe the Maxima will be quicker. First the closer ratio tranny should yield better acceleration. Second the approx. 8.5 hp advantage will also yield better times.
Regards,
Rudy
Old Oct 6, 2001 | 10:44 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
this dissertation was brought you by.......
Old Oct 6, 2001 | 10:52 AM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Re: Maxima 6sp vs. Altima 5sp
Regards,
Rudy
finally some who is smart and reads the facts.
Old Oct 6, 2001 | 11:45 AM
emax02's Avatar
Regards,
Rudy
I wonder the difference in wheel weight between the two? This could play a key role if the difference is substantial. Also the max has fatter tires "225" compared to "215" on the Altima, this should help off the line traction a little bit for the max . BTW nice write up Rudy.
Old Oct 6, 2001 | 02:08 PM
Amazing2's Avatar
Rudy (wolfmanjack210),
I like the www.Nissan.ca numbers even more:
2002 Altima SE 5 speed = 3,191
2002 Maxima SE 6 speed = 3,221
A difference of: 30 lb.
mrc00l88
Jan 25, 2024 01:14 PM
soon2ownmax
Aug 13, 2015 02:19 PM
altmycar
Aug 6, 2015 04:44 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
alejoa33a34
Aug 5, 2015 09:21 AM
