are hubcentric rings necessary?
Originally posted by skimax
one of my rim is missing it? if it isn't necessary then no need to go buy one...
-Shing
Necessary
The purpose of the ring is to have the axle support the wheel, while the bolts hold it on. If the ring is missing, all of the force is transferred to the bolts, which should make the car (at least marginally) less safe.
Originally posted by Shingles
If you odn't mind vibrations etc, then you don't need to use it. But if you like a smooth ride, you should.
-Shing
-Shing
Re: Necessary
hmmm.... I have a stupid question.....I remember -->
receiveing mine when a I bought my wheels and never used them......I guess I should install them.
My stupid question is.....do these mount on the inside of the lugs on the hub or the outside of the lugs on the hub?
Re: Necessary
Ah.. the rings will help keep the wheel centered to help reduce vibrations. But considering these rings are either thin plastic or metal, they do not do much for support if any.
Re: hmmm.... I have a stupid question.....I remember -->
-Shing
Re: Hmmm...still lost....
How do you mount these ON the rim......I figured they should go around or inside the lugs ON the hub.....
BTW this really could be a reason why you are having warped rotors. Because the rims may not be centered right, it will shake and vib.... when you brake... I will cause different pressure on the rotors.
-Shing
Shing.......sometimes I hate you -->
when you point this stuff out.
THAT'S WHY I'M WARPING ROTORS?
WTF?
Great, now I'm going to have to go home and dig through my attic (thank goodness we haven't been in the house long) and play with my wheels this evening AND continue painting our bedroom....
I really hope I actually have 4 of them, but I'll probably only have 3 or something.
I assume Pepboys/Autozone has these things....
WTF?
Re: Shing.......sometimes I hate you -->
Let me know if you need some... I have 4 spare ones.
BTW did you know the hub on the maxima is the same as the crx?
As for the rotors warping... tires that arn't balanced could cause tire warpage, so can not torquing the rim down probably... the reason is b/c they all cause shakes. If you don't use hub ring, it will do the shake too.
Thus that could be your rotors.
-Shing
-Shing
WTF?
WTF?
I've been running the Mustang wheels that have a larger hub bore bore for about a year and no warped rotors yet. Bill have you rebuilt your calipers yet? Maybe some of the slide pins are gummy and are putting uneven pressure on the rotor surface?
[Edited by Jeff92se on 11-01-2000 at 05:43 PM]
Are they all the same no matter what aftermarket rims you have?
Reason I ask is because I ordered them from the same company that I bought my wheels from. When I got the things...they didn't fit right..they had to be dremmal tooled down to make them fit right. They were the right part#..size etc. too.
Pied
Sep 26, 2015 03:29 PM
95Maxi
Aug 25, 2015 08:01 PM
