Torque Wrench
If you don't care about name brand, Harbor Freight has them for $20-$30, even cheaper when there's a super sale.
I have a $60 Husky and a $25 Harbor Freight (no brand name) torque wrench (got if for $10 during a super sale), and they both work just fine to me.
for Harbor FreightI bought mine from there for $12.99. It's a clicking, ratcheting, 1/2" torque wrench that is very accurate. One time, I tested it up against a clicking snap-on torque wrench and it was just as accurate. Harbor Freight also has a lifetime warranty on all of their hand tools. I don't know how they do it.
Uhhh, which one do you have that you have a lifetime warranty on a torque wrench? all the ones I've seen are under 2 yr warranty and only like 90 days on calibration...
is there such a thing as an extendable torque wrench with a U joint?? like one that starts at 7 or 8 inches and extends to 15 or 16?
i was asking so i could use it to get the right foot lbs on the knock sensor im gonna do in the next few weeks.
Highly doubtful since Torque is a measure of Force x Distance. Extending the wrench would increase the torque and the wrench wouldn't be able to compensate for it, and having the U joint and introducing angles would complicate/alter the force being executed. If a wrench like this existed, it would be $500 plus.
Same here. Did find out that Home Depot (Husky) was warrantied for life though. At least when I bought mine last year they were.
I have an older sears one that seems to be serving well.
/side question
Where do you guys get them calibrated, and how much does it usually run to do? Is it so much, that it's worth just buying a new one?
/side question
Just in case there may still be one soul on this thread that wasn't aware, the easiest way to put a torque wrench out of calibration is to finish using it and store it away WITHOUT releasing ALL pressure/tension on it first.
Yup, I always put it at the lowest setting before putting it away.
so how would i go about measuring the torque on the knock sensor when im installing it WITHOUT removing the manifold?
just goodntight will work? i think the specs are 14-22 ftlbs
Mar 12, 2020 12:06 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Hdnseek
Sep 9, 2015 05:55 AM
Not sure how accurate it is now.
