Wanting to relocate MAF sensor, but would extending the wires cause ill effects?
Old Oct 22, 2001 | 08:01 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
I want to get rid of the intake piping on my SC and make a CAI like the 4th gens, but here's the problem. Stillen put the MAF tube right after the filter instead of integrating it with the charged air piping.
So the question is, will extending the MAF sensor wires have any side effects? Any help will be greatly appreciated. Thanks in advance.
Old Oct 22, 2001 | 08:30 AM
MardiGrasMax's Avatar
Re: Wanting to relocate MAF sensor, but would extending the wires cause ill effects?
If you do a nice job with some solder and heat shrink it should be ok. Wire nuts and duct tape are a no-no.
Old Oct 22, 2001 | 08:36 AM
Y2KevSE's Avatar
Re: Re: Wanting to relocate MAF sensor, but would extending the wires cause ill effects?
No wire nuts and duct tape.
Thanks for the reply.
Old Oct 22, 2001 | 08:38 AM
CandiMan's Avatar
Say Candyman 5 times
Originally posted by MardiGrasMax If you do a nice job with some solder and heat shrink it should be ok. Wire nuts and duct tape are a no-no.
What's up Kev, I agree with the above statement. Also use the same gauge or larger wire as the OEM harness. Something tells me you knew these suggestions already, and don't forget my pics
Colonel's Avatar
Old Fuddy Duddy
I think he was looking more along the lines if the resistance of the extended wiring will change the output of the MAF to the source and cause undesireable results.
My GUESS (take it as that) is that if you use the same gauge wire and are under something like 2.5 to 3 feet additional, there should be no distinquishable change in the resistance along the line. But I am NO EXPERT. But I did stay at a Holiday Inn Express....(he he he...ugg)
Old Oct 22, 2001 | 08:46 AM
Y2KevSE's Avatar
Re: Re: Re: Wanting to relocate MAF sensor, but would extending the wires cause ill effects?
Hi Mike! Having fun on the East Coast yet?
What pics?
Any info on the project you and your friend was working on yet? Or is that dead now?
Old Oct 22, 2001 | 08:49 AM
Y2KevSE's Avatar
You are correct. I should've clarified that in the first post. Thank you for doing so.
I'm going to bring the MAF sensor to the other side or the engine bay and through the large hole near that's near the windshield washer fluid.
Old Oct 22, 2001 | 08:51 AM
CandiMan's Avatar
Re: Re: Re: Re: Wanting to relocate MAF sensor, but would extending the wires cause ill effects?
Originally posted by Y2KevSE Hi Mike! Having fun on the East Coast yet?
What pics? Any info on the project you and your friend was working on yet? Or is that dead now?
Can't have fun until my car arrives (it was shipped)
As for the project, it's not officially over. I just can't bug him as much as before. I'll send you a email or pm in a few days once I get an official answer
Old Oct 22, 2001 | 08:54 AM
Y2KevSE's Avatar
Re: Re: Re: Re: Re: Wanting to relocate MAF sensor, but would extending the wires cause ill effects?
Sounds good! He can go ahead and press it out. Thanks Mike!
Old Oct 22, 2001 | 08:56 AM
Good point, I would recomend a high quality wire of the same gauge. Be sure it is a low impedance wire, they usually have many thin strands inside. Cheeper wire uses fewer large strands, wich should not be used for this application.
Old Oct 22, 2001 | 09:01 AM
Y2KevSE's Avatar
I have Home Depot wires... that wouldn't be considered "high quality" wires, would it? They do have many thin strands though.
Old Oct 22, 2001 | 10:03 AM
Colonel's Avatar
Old Fuddy Duddy
Another thing to think of is make sure it has a silcon or silicon based jacket. Or in the future water seepage might be an issue.
Old Oct 22, 2001 | 10:05 AM
Y2KevSE's Avatar
Ahhhhhhhh........ OK. Jacket? Please clarify.
Thanks.
Old Oct 22, 2001 | 10:11 AM
Colonel's Avatar
Old Fuddy Duddy
Thanks.
Sorry...sleeving/coating...the colored part. I always called it a "jacket" not really sure the technical word for it. Some of the cheaper wire coating is just plastic and won't weather well under the "conditions" underneath your specific hood area causing oxidation of wires and yet more problems.
I think you can measure resistance using a DVM between 2 points.
Old Oct 22, 2001 | 10:20 AM
Y2KevSE's Avatar
Gotcha. Thanks!
Old Oct 22, 2001 | 10:23 AM
DanNY's Avatar
Ad·min·is·tra·tor
the word you're looking for is...
"insulation"
just get decent quality wire kev. put a sealing butt splice on the ends of the wire. heat the splice so it's waterproof. slide heat shrink tubing to the entire bunch of wires. heat that up so it's water resistant in between.
make sure the MAF doesn't get wet.
Old Oct 22, 2001 | 10:57 AM
Y2KevSE's Avatar
"insulation"
Thanks Dan! I was planning on doing the exact same thing you mentioned. Great minds think alike.
Old Oct 23, 2001 | 12:19 AM
mingo's Avatar
get phoenix gold zero point wires.. they are very gooooOood... like my purple wire/python it's GooOod... and yummy too.
Old Oct 23, 2001 | 12:45 AM
brianw's Avatar
I wouldn't do it. SE-R guys have had some bad experiences, but I've only heard of 1 case where this was done.
1 case is not exactly a good sample.
kjlouis
Nov 24, 2018 06:09 AM
vanebecker
Aug 19, 2015 09:45 AM
Abdelrhman
Aug 17, 2015 12:16 PM
doobadoo
Aug 15, 2015 06:43 PM
