RF CV axle moves
Old Nov 21, 2007 | 03:07 PM
talisman311's Avatar
RF CV axle moves
So I was under my car today and noticed something peculiar. I'm not sure if this is normal or not since I had the axle replaced about a year ago. It slides maybe a cm back and forth. I didn't really try to move it up or down, but I thought once the snap ring is in place, there shouldn't be any play where the axle goes into the transaxle housing.
Anybody?
EDIT: LEFT FRONT, DOH
Old Nov 21, 2007 | 03:15 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
I replaced mine last week... does the same thing. There is a slight play in it but I'm not sure if it's suppose to be like that or not. Considering the ones I took off were fu<ked up for real.
Old Nov 21, 2007 | 03:19 PM
Longhorn101's Avatar
That doesn't seem right. I just replaced my right front (passenger) side CV and it doesn't have a snap ring to hold it in but it is basically held in place by a bearing mount with 3 bolts about halfway between the wheel and the transmission housing. You might take a look at those bolts and make sure they aren't loose. Good luck.
Old Nov 21, 2007 | 10:47 PM
A33 VQ30DEK's Avatar
Anybody?
It could be a sign of a bad transmission bearing if the axle moves up and down and side to side.
Old Nov 22, 2007 | 01:03 AM
DasYears
there shouldnt be a snap ring. and it also shouldnt move at all
Old Nov 22, 2007 | 05:14 AM
Ugh, I don't know what I was thinking. It's the left front CV axle, not the passenger.
Old Nov 22, 2007 | 06:36 AM
brio_max's Avatar
Learning English...
Any pics?
Old Nov 22, 2007 | 10:29 AM
DasYears
there is some play in the cv joints, but you should only be able to make them pull out if there is room to do so, which there shouldnt be
Old Nov 22, 2007 | 10:59 AM
kzoosho's Avatar
yea it shouldnt be ableto coe out on itrs own but it should move .
Old Nov 22, 2007 | 06:19 PM
Don't have the ability to take pictures, I'm away from my car with family right now. It doesn't come out completely, but it does have a little lateral play, so I guess I'm alright. Thanks for the response guys.
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
