***HELP*** 03 maxima lights went out!
Old Dec 14, 2007 | 05:25 PM
stronium_95se's Avatar
Hey guys,
I just changed my courtesy door lights to leds and then when went to try and change the clearance lights they didnt work. After I tried installing them in the headlights, all my sidemarkers, interior gauge and rear tail lights dont come on anymore. The bulbs aren't burned either because I tried testing them back on the door and they worked. I think its some kind of fuse that may be burned but i have no idea how to get this fixed? can anyone help please?
btw my headlights and fogs still work, just the interior, sidemarkers, clerance lights, and tailights dont come on.
Old Dec 14, 2007 | 05:30 PM
vqmaxman's Avatar
It has to be your fuse in your dash under the steering wheel.
Old Dec 14, 2007 | 05:32 PM
do you know which one it is and how I would fix it? just buy the same type of fuse from autozone and pop it in?
Old Dec 14, 2007 | 05:39 PM
vqmaxman's Avatar
You have to pop out the cover and look on the back and it should say what fuse and what each of them do and yes, you can replace it by getting one from the Autozone.
Old Dec 14, 2007 | 05:48 PM
vqmaxman's Avatar
There should be one main fuse that will take out the power to everything ELECTRICAL interror amd exterrior.
Old Dec 14, 2007 | 05:49 PM
ROCKART's Avatar
wants an I35
wrong forum
Old Dec 14, 2007 | 06:01 PM
thanks, but would you happen to know which one it is specifically? and what could i have done to blow it? all i did was replace a bulb.
Old Dec 14, 2007 | 06:06 PM
vqmaxman's Avatar
I am not sure about the 4th gen having the same fuse numbers as they would in the 5th gen. The fuse could of blown out cause you have tryed the wrong bulb in the wrong voltage socket or there could be a short.
Old Dec 14, 2007 | 06:19 PM
vqmaxman's Avatar
Do have any power to your interrior exterrior lights anything lighting up?
Old Dec 14, 2007 | 06:20 PM
the ac lights turn on, courtesy door lights, dome, headlights and fogs work and tail lights only work when i press down on the brakes.
Old Dec 14, 2007 | 06:24 PM
vqmaxman's Avatar
ALL of this works when you have your foot on the brake pedal down.?
Old Dec 14, 2007 | 06:26 PM
oh no i meant the tail lights only come on when i press down on the brakes. they're suppose to be on when i have the lights on at night so now its completely dark when i drive
Old Dec 14, 2007 | 06:30 PM
vqmaxman's Avatar
Try this fuse # is 7.5 A in the ACC section.
Old Dec 15, 2007 | 07:15 PM
fixed!! it was the tail lamp fuse under the hood that went out, thanks for the help!
Old Dec 16, 2007 | 05:27 PM
nismos14's Avatar
§è~® f®ÈÄk
Haha gotta love when its just a little fuse, eh?
EuroDriver
Sep 14, 2015 06:08 PM
Samedi
Aug 13, 2015 04:05 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
MikesChevelle
Aug 6, 2015 11:36 AM
yat70458
Aug 3, 2015 01:16 PM
