Question for all you guys with CF hoods
Old Jan 10, 2008 | 04:04 PM
dutch078's Avatar
keep it metal
Hey hey guys, have a question for you. I read somewhere that due to it's lighter weight, a CF hood should not be operated with factory hood struts. Is this true, or a load of crap? I understand that an OE hood is a lot heavier and requires a stronger strut, but I don't think I've ever come across a "special" hood lift for a CF hood. Any ideas or feedback?
Old Jan 10, 2008 | 06:35 PM
jonmandude's Avatar
I have no hood struts on mine. I have heard the same statements and decided not to chance it. CF flexes and I think the pressure of the struts pushing against the weakest part of any hood, the center of long straight panels, may possibly cause damage. And I am not willing to risk damage to that kind of money.
Old Jan 10, 2008 | 06:47 PM
Professor's Avatar
I wouldent take the risk.
Old Jan 10, 2008 | 06:51 PM
dutch078's Avatar
keep it metal
hell, i wouldn't risk it either
Old Jan 10, 2008 | 08:12 PM
ThurzNite's Avatar
Like taking a wool sweater outta the wash and stretching it... It's just not gonna be the same.
Dr J
Old Jan 10, 2008 | 08:51 PM
DasYears
what do you guys use instead? no struts or are there actually softer struts out there for the max?
Old Jan 11, 2008 | 12:57 AM
CreativeSkillz's Avatar
Do they make a CF hood for the 5th gens? Whats the weight difference?
Old Jan 11, 2008 | 02:32 AM
jonmandude's Avatar
I use a piece of 1" PVC pipe to hold up the hood when I need it up.
Also thinking, while you are after CF for weight savings (and it looks good) save the weight of the struts too.
Old Jan 11, 2008 | 09:06 AM
dutch078's Avatar
keep it metal
http://www.andysautosport.com/nissan...n_fiber_hoods/
Old Jan 13, 2008 | 09:44 AM
aznsap's Avatar
do cf hoods come w holes drilled for struts even?
i bet you could use blown/weakened struts
Old Jan 13, 2008 | 03:41 PM
jonmandude's Avatar
Mine did not come with holes for the struts, or for washer nozzles. I cannot speak for other hoods.
Old Jan 14, 2008 | 12:51 AM
My CarbonFX hood has the holes drilled for struts.
I tried to use the struts, but it seemed and felt like I was going to snap the hood in half as I tried to close it for the first time. I swear I heard cracking noises and stopped immediately. Thus, I don't use struts. Hood pins for me. And like someone suggested, it's more weight savings.
Exactly! This works.
Old Jan 18, 2008 | 09:15 PM
lunchbox's Avatar
I had a custom hood prop made for mine. It came off a 97 S10. It was really simple, and it worked really well...plus it looked pretty stock.
Old Jan 18, 2008 | 09:27 PM
Nightkid08's Avatar
try some busted hood struts, may not be strong enough for the oem hoods but may be just right for cf.
Old Jan 19, 2008 | 02:17 PM
MDeezy's Avatar
I replaced my hood struts a long time ago with some from autozone. held up the oem hood fine. got my CF hood put on, functions just as great. no problems
Old Jan 20, 2008 | 09:28 AM
matty's Avatar
I use hood struts on mine. No problem
-matt
Old Jan 20, 2008 | 08:19 PM
dutch078's Avatar
keep it metal
well i think with my refund form uncle sammy i may finally get my CF hood. sweet!
Old Jan 21, 2008 | 03:35 AM
DasYears
were they supposed to be OEM replacement or just a set of crappy low press struts?
Old Jan 21, 2008 | 03:41 AM
max95q's Avatar
Yeah, some guys used old worn hood struts that wouldnt hold up the OEM hoods for crap and used those.
maxipower
Aug 21, 2015 11:10 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
wingsfan24
Aug 15, 2015 07:35 PM
doobadoo
Aug 15, 2015 06:43 PM
ramtin325i
Aug 8, 2015 05:13 PM
