Help! Put key in, turned , no crank + more probs.
Old Nov 12, 2001 | 12:22 PM
tunedup's Avatar
what is the cause of this, i have a 95 is it the starter?
also, i press lock on my keyless entry and all hte doors jus made this noise like the lock was jammed.
same w/ the trunk.
same with the lock button on the driver door
what is going ON?!?!?!?
Old Nov 12, 2001 | 12:28 PM
Sprint's Avatar
first thing you need to check is if you have power..
so when you turn the key.. check to see if you have lights on your dash, or if you have clock or head lights.. if you do.. then its your starter..
if you don't?
if you don't and you never had a battery light, you battery is dead and you just need a jump..
if you don't?
and you had a battery light before.. your altenator is dead
Old Nov 12, 2001 | 06:04 PM
black97max's Avatar
I have been having the same problem. This happens every so often.I try to start my car and its a no go. BUT my lights, clock etc. all come on..... Do you think my auto remote start may have something to do with this?
tsi6001
Oct 3, 2022 10:23 PM
alixc
Aug 11, 2020 01:48 PM
cruce91
Sep 20, 2015 10:23 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
sc10692
Aug 9, 2015 09:37 AM
