Larger tire size/new tires...need help!
Old Nov 14, 2001 | 09:20 PM
GVW's Avatar
GVW
I have a 97 SE with factory size 215/55/16 tires on it. I am considering going to 225/55/16 for increased handling. Has anyone else upgraded to the newer size? If so, did you have an issues with them fitting on the rim or any problems with them rubbing?
Thanks, also if anyone has any suggestions on either H or V rated tires, I would love to get some feedback. I have looked at so many and am not sure what to get at this point. I have Yokohama AVID V 4s and am considering H rated Bridgestone RE950s.
Thanks in advance
Old Nov 14, 2001 | 10:15 PM
RedMax95's Avatar
Re: Larger tire size/new tires...need help!
Thanks in advance
love these lurkers, at least half these people have different tires and rims, i dont have any rubbing probs on my 17s and they are 235/45/17, btw get a smaller sidewall, it looks better, oh and dont forget the 2 inch drop
Old Nov 15, 2001 | 12:49 AM
PeaBodyJones's Avatar
Thanks in advance
225 will be fine but i would recommend getting a 50 or 45 sidewall instead of 55. you will look like u have bus tires if you dont...and yes, lower the car too. handling will not increas much by adding wider tires but lowering the car and wider rims will work wonders. but what do i know? i drive a 82 maxima!
Old Nov 15, 2001 | 12:56 AM
ngthing's Avatar
When you change your sidewall height, your speedo will be off, make sure you compensate for that when you're driving.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
