First Tune up in over 2 yrs
Old Jan 26, 2009 | 09:46 AM
MaxBlack97's Avatar
I am going to do my first rune up in a long time when I get my tax money. I wanted some suggestions on all the things I should look to change and all the fluids I should replace. I know have to change my spark plugs cuz I did a motor swap about 2 yrs ago and the new motor had about 53K on them, so those should b about 15K over the replacement mark lol. Anything else you guys can recommend, thanx in adavance.
Old Jan 26, 2009 | 10:06 AM
IHAVEA2KMAXIMA's Avatar
Blinker fluid for sure! lol
How many miles on the car btw?
Old Jan 26, 2009 | 12:52 PM
Scottwax's Avatar
That's Mr. Detail to you
Might want to consider the NWP intake spacers since you have to pull the intake to get to the rear bank so you can access the plugs.
Old Jan 26, 2009 | 01:57 PM
Maxgig's Avatar
Don't forget the highly overlooked cabin filter.
Old Jan 26, 2009 | 02:06 PM
wyche89's Avatar
engine oil, tranny fluid, power steering fluid, brake fluid, clutch fluid, coolant, air filter, spark plugs... i think that's it?
oh yeah.. blinker fluid
Old Jan 26, 2009 | 02:42 PM
Bjs470's Avatar
what about headlight fluid??
Old Jan 26, 2009 | 02:50 PM
maximadudeIIs's Avatar
I would change the following: engine oil, air filter, oil filter, coolant, trans fluid, power steering fluid, and spark plugs.
Also check brake fluid, CV joints, suspension, exhaust, cabin air filter, brake pads + rotors, steering components, exhaust, drive belts, radiator hoses.
Old Jan 26, 2009 | 02:58 PM
Pearl93VE's Avatar
I can has?
Aside from the normal tune up items:
Spark Plugs
Check Coils for cracks
Air Filter
Fuel Filter
Oil/Oil Filter
Brake Fluid color/level
Power Steering level
Cabin filter (if applicable)
PCV valve
etc.
I would also CLEAN and check the following:
Air Intake tubes (Throttle body and intake cleaner)
Throttle Body
Idle Air Control Valve
MAF (electrical contact cleaner of MAF cleaner)
Coolant Temp Sensor
Knock Sensor
I would also look into the phenolic intake spacers as mentioned above for cooling down the IM/ adding a little power.
Old Jan 26, 2009 | 03:55 PM
MaxBlack97's Avatar
Thanx fellas, u guys were very helpful, any advice on spark plugs I should use for my 3.5?
Old Jan 26, 2009 | 05:14 PM
Pearl93VE's Avatar
I can has?
I would assume NGK plats
Old Jan 26, 2009 | 09:17 PM
wyche89's Avatar
go plat or go home
Old Jan 27, 2009 | 06:50 AM
hoyshnin's Avatar
Baby's on the Half Tip!
stick with ngk, whatever you get (platinum or regular)
Old Jan 30, 2009 | 10:01 AM
trooplewis's Avatar
Any recommendations on fuel filter brand? Do you guys us OEM? There are about 6 other choices including Wix, which I like.
Also, any recommended online parts sites that are best for prices?
Old Jan 30, 2009 | 11:09 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
wat
PCV replacement
Chevron Techron
Seafoam via Brake Booster
Throttle Body wipe down IF 5th gen only
Old Jan 30, 2009 | 01:30 PM
MaxBlack97's Avatar
thanx u dudes were real helpful except for u dudes wit the blinker/headlight fluid stuff, I will look into the ngk plats and try to find the best price, I am 3.5 wit about 180K, got the motor wit 52K, installed it at about 145K I think (cant remember exactly). I know I gonna stick wit hawk pads cuz I luv their grip, but anyone got any suggestions on rotors?
Old Jan 30, 2009 | 01:32 PM
Mr.A32ftw's Avatar
Brembo blanks
Old Jan 30, 2009 | 03:32 PM
Pearl93VE's Avatar
I can has?
Originally Posted by mariosmax
Brembo blanks
+1, been using them for years
Old Jan 31, 2009 | 10:57 AM
trooplewis's Avatar
"Throttle Body wipe down IF 5th gen only"
4th gens do not need TB cleaning?
Old Jan 31, 2009 | 11:31 AM
trooplewis's Avatar
1) can anyone lend some insight to the NWP mod, since there are a gazillioin hits when searching, since everyone has it in their sig.
2) It's not really necessary to pull the intake manifold to change plugs on the rear bank, is it? I need to do that soon.
Old Jan 31, 2009 | 11:56 AM
wirelessdude04's Avatar
Spark Plugs
Air Filter
Fuel Filter
Oil/Oil Filter
PCV valve
etc.
Throttle Body
Coolant Temp Sensor
Knock Sensor
You know your maintance well my friend.. Also check tires for wear, tire pressure
Old Feb 15, 2009 | 08:41 AM
Rob_0126's Avatar
Not to highjack, but do you have to pull the intake to get to the plugs on a 95 max?
Old Feb 15, 2009 | 08:36 PM
Leo_Koneval's Avatar
Hey guys what kind of fluid does a 1997 Nissan Maxima use for the blinkers? I was thinking about replacing the air filter fluid too, but I realized that I had forgotten to replace the E-Brake handle fluid and so I had to do that first. The guy at Grease Monkey freaking charged me a lung and kidney to replace it!
Old Feb 16, 2009 | 09:34 AM
trooplewis's Avatar
You guys really replace your power steering fluid???
Old Feb 16, 2009 | 03:08 PM
K.Hall's Avatar
go plat or go home
DEFFFFFFFFFF
Old Feb 25, 2009 | 04:52 PM
MaxBlack97's Avatar
Originally Posted by K.Hall
DEFFFFFFFFFF
Thanx fellas, I was thinking of switching up and trying the ngk iridiums becuz I hear they supposedly to perform better but I wouldn't wanna change them more often so I think I may just stick wit the oem plats
Old Feb 25, 2009 | 06:28 PM
a33i30's Avatar
Doesn't iriduim last as long as the plats?
Old Feb 27, 2009 | 11:43 AM
MaxBlack97's Avatar
I actually heard the plats last longer and that the 3.5 comes stock with the plats also.
Old Mar 7, 2009 | 11:33 PM
Brianm0121's Avatar
power steering fluid, coolant, brake fluid
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
mclasser
Sep 24, 2015 11:57 PM
Maxboy23
Sep 4, 2015 06:04 PM
