Well, there's the problem
Old Jan 31, 2009 | 06:01 PM
secondtonone317's Avatar
nycnissans
(mods, sorry if this is the wrong section)
Took a little time this afternoon to tear down this motor (VQ30DEK) and see exactly what went wrong. Qmax03 (Qazi) came over to let out some anger and lend a hand. Son was beastin on those headbolts.
I also got to salvage the 3.0 timing equipment and learned alot during the teardown.
I can't get over the fact that the pistons on my DEK were so fagile looking. Its something that you have to feel in your hand to understand what im talking about. I deffinately understand why these motors can't hold alot of boost or juice. The tops of the pistons feel really thin.
On a positive note the DEK headgasket is metal and that **** HOLDS, no sign of headgasket failure even with 2 fucced up cylinders and an abused head.
If you want any parts from this motor just let me know.
Here's the motor with just the outer timing cover of.
Inner timing cover off and cams out
When you pull the heads off, this is what its supposed to look like
nycnissans
But check this
1 more time, normal
its ****ed up
Old Jan 31, 2009 | 06:02 PM
nycnissans
head got messed up too
yup, you ****ed it up
but both head gaskets were still good
Q finishing up the teardown
Old Jan 31, 2009 | 06:03 PM
nycnissans
Bare block, not heavy at all
Old Jan 31, 2009 | 06:30 PM
maxboy325's Avatar
Wow! was this motor running spray?
Old Jan 31, 2009 | 07:00 PM
nycnissans
nah no spray
Old Jan 31, 2009 | 07:12 PM
98maxse5spd's Avatar
Did you have to share one set of gloves for the teardown?
How many miles were on that thing?
Old Jan 31, 2009 | 07:16 PM
nycnissans
you know the economy is rough and these gloves...............lol
around 130k
Old Feb 1, 2009 | 08:20 AM
nycnissans
if anyone is local and wants the block or any other parts shoot me a PM, free of charge
Old Feb 3, 2009 | 11:51 PM
Dave Holmes's Avatar
Extremely interesting. Those pistons definitely look like a weak point in the motor. The headgasket is impressive, though. Eases my mind when thinking of the possibility of blowing one.
If you weren't spraying, please tell me you were running ridiculous boost. I haven't heard of any other VQ destroying their pistons, so I'm wondering what was up.
Are there aftermarket pistons available for the VQ30? Would seem to be a good thing to do if spraying or boosting. I thought I'd read years ago that the VQ30 was capable of withstanding about 450 hp (via boost or spray) without internal mods. Maybe I'm remembering it wrong.
Dave
Old Feb 4, 2009 | 06:21 AM
mtrai760's Avatar
'Trynna' is not a word
He is boosted.
Old Feb 4, 2009 | 06:23 AM
nycnissans
Dave
Well I was running a 2.87 pulley which gave me 12-14 psi depending on air temperature and density (?). I also have meth injection and it dynoed 369 untuned and with using winshield washer fluid instead of real meth. I then street tuned and got real meth at that point the HP was upwards of 400 maybe over but I can't back that up since I never re dynoed.
My theory on this is as follows. I was doing a burnout to warm up some drag radials, and the RPM kinda bounced a bit too much which is what I believe led to violent vibrations and the piston slapping the head which cracked the first piston (middle cylinder towards front of the car). The chunk of that piston rattled in there a bit and probably broke into a hundred pieces and flew out the exhaust valves. The other piston probably cracked the same time as well who knows? I continued to drive the car for about a month after that without any knocking but it was burning a considerable amount of oil obviously. It didn't pull as hard, now I know why then one day I ran it low on oil and it started to knock and that was when I figured I would yank it out.
I mean I'm no pro or anything, this is just my common sense observation or what I think happened. I can say this tho, if I didn't bounce it off the limiter so much this would not have happened.
As far as piston options a full DET swap would be nice pistons, crank, rods, and I think Arias also makes pistons for the 3.0. I heard someone also said STI bore is the same as the 3.0, not sure.
Old Feb 4, 2009 | 09:23 PM
MadMaxSE-L's Avatar
Doggah Bite...
Meh - you shoulda cranked up the boost a little more and sprayed it before you took the engine out...
But nice job on fukin up some parts non the less
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
