Little Help Please
Old Nov 18, 2001 | 01:18 PM
barrett58's Avatar
Little Help Please
Was trying to clear out my tail lights. Gave up for today since I don't have the right tools. I need a dremel.
Anyway.. I got that glue on the taillight and it is impossible to get off.
What kind of product can get this gooey shiit off my light??
Old Nov 18, 2001 | 02:39 PM
njmaxseltd's Avatar
Any good cleaner wax should do the trick. Meguires or Mothers works great. Just polish it away!!!
Old Nov 18, 2001 | 02:51 PM
Sprint's Avatar
don't use wax or polish on the tail lights..
use dish soap.. it comes right off..
if not..use a heat gun.. get the glue a little hot.. i have done over 50 tail lights.. and dish soap gets it off all the time
Old Nov 18, 2001 | 02:52 PM
yourmove's Avatar
Try a little masking tape and tack it off! If this isn't working all that well, blot a little nail polish remover (acetone) on there and continue to tack off with tape.....Do not rub as this just speads it!
Old Nov 18, 2001 | 03:06 PM
Sprint's Avatar
NO!!!! that will eff up the lens..
where are you guys getting this stuff? wax? acetone? wtf???
DISH SOAP man DISH SOAP
Old Nov 18, 2001 | 03:15 PM
yourmove's Avatar
Sprint, I've done this before....It works fine! I would never miss inform someone. If I did not know, I say nothing! If dish soap works......Cool!
Old Nov 18, 2001 | 03:22 PM
barrett58's Avatar
thanx
Thanx guys..I 'll try it tomorrow because it gets dark so early. I totally fudged up my clear lights. Didn't think it would be so hard. I have to pick up a dremel tomorrow. Thanx
Old Nov 18, 2001 | 03:26 PM
yourmove's Avatar
Re: thanx
If your buying a dremel to cut the clear plastic, you can use a soldering iron. Just cut it over size and sand it to fit! Soldering iron you might already have and if not it's much cheaper.
Old Nov 18, 2001 | 03:44 PM
barrett58's Avatar
I was going to buy a dremel anyway because they are come in handy with all the attatchments. Thank for the advice guys. Hopefully it looks decent.
another question.
I see a lot of guys put them in the over..but there was no unanymous approach(some say 15 some 5). What if I preheat the oven at 200, then put in for 5 minutes and check it?
Old Nov 18, 2001 | 03:53 PM
yourmove's Avatar
another question.
It will definately not need 15 minutes! 200/225F, 5min. tops.
Old Nov 18, 2001 | 04:09 PM
Sprint's Avatar
well i know paint thinner kills the lens.. makes it warp.. i appologize for my ignorance
Old Nov 18, 2001 | 04:11 PM
Sprint's Avatar
i use a heat gun.. makes me control my work easier..
when i started i used a soildering iron.. then i figure i would do them for some cash so i bought a dremel.. now it takes me 15 mins to do each light.. from start to finish
Old Nov 18, 2001 | 04:16 PM
yourmove's Avatar
No man, no ignorance at all! If you were to bathe the lens in this harsh chemical it would comprimise it's clearity!....However, I was hoping this person would yeild at my words of "a little" and "blot" !!
