will a de-k tb work on a 3.5
Old Mar 29, 2009 | 01:07 PM
Product_Of_Korea's Avatar
didnt know where to put this it could go in all motor.
but exactly what the title says. im trying to avoid making my own bracket or getting a mallfinder tb. i have the tools to drill my own holes if need be i just want to know if it is possible
Old Mar 29, 2009 | 02:15 PM
DrunkieTheBear's Avatar
Turbo'd Saab
so your going to use this in your 4th gen with cables correct? and you have a 3.5 setup?
Then yes with the resources it will work (drills), it would just be like doing the 00vi swap essentially
Old Mar 29, 2009 | 07:20 PM
yeah i think that were on the same page.
I have a 4th gen that i will be swapping in a 3.5 and i was curious about putting the 5th gen tb(off the 00vi) onto the 3.5 by drilling.
Because isnt the PF Tb and the de-k tb essentially the same minus the bolt pattern??
little off topic but didnt you use to be davevq?
Old Mar 29, 2009 | 08:32 PM
Turbo'd Saab
Yes I was DaveVQ, Until I own a VQ again(which should be in a month or two), I'm Drunkie.
Pathy TB is suppose to bigger bore IIRC, but I had my 5th gen TB bored out to 70mm by Proflow.
I could see this being a good alternative then having to convert the drive by wire TB and make it easier to reuse the TPS and IACV.
Old Mar 30, 2009 | 08:05 AM
k thanks man looks like ill be selling my 00vi with a 4th gen tb.
maxinout93
Oct 27, 2015 01:29 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
maxinout93
Aug 16, 2015 07:25 PM
kenc15
Aug 5, 2015 08:29 AM
