Problem Non-Gen Specific
Recently my manual transmssion in my 1998 Maxima went. Non Locking Diff(Dont know if that matters) When i say went i mean a seal, a cracked case, something went wrong. I cant shift into some gears and others are sometimish. I cant even drive the car.
My problem:
Im removing the transmission but the gearbox has grabbed the axles and is refusing to let them go. What methods can I take to get the driver side axle out? so that i can drop the tranny and inspect it further.
Thanks In Advance Guys
My problem:
The dirvers side is usually the easy one to get out.
Did the passenger side come out?
If you get one out, use a hammer and rod and go at it from the opposite side.
If you can't get them out, take them apart and leave the inner CV joint on the tranny.
i have pulled, used a pry bar. when i try to turn the axle left or right i feel oppression meanin let say the axle was 12oclock i get half the distance to 1 oclock and half the distance to 11 oclock.
James92SE
142
Jan 2, 2024 09:23 AM
alphakaoz
Sep 30, 2015 07:33 PM
ColdCananda
Sep 20, 2015 10:45 PM
make sure its in neutral
