how do i put this new coilover together???
Old Nov 24, 2001 | 06:15 AM
98MAX's Avatar
my right rear coilover broke, i have a new one but i cant figure out how to put it together.
Old Nov 24, 2001 | 09:57 PM
max'n out's Avatar
U might wanna say what kind of coilover it is.
Old Nov 24, 2001 | 10:08 PM
Sprint's Avatar
if it broke its cattman
Old Nov 24, 2001 | 11:10 PM
ohboiya's Avatar
that's what I was thinking ... you'd think that if you're paying $1600+ you wouldn't have such issues ... but then again ... I'm going from second hand knowledge ...
Old Nov 24, 2001 | 11:48 PM
I30CeFiRo's Avatar
Yep, both of my rear Cattmans broke...twice!!
Old Nov 25, 2001 | 12:21 AM
98MAX's Avatar
My bad, it is cattman. It broke and I have the rear on like 3 so it would not brake.i have the new shock but i cant figure out how get the threded piece off the broke one and on the new one.
Old Nov 25, 2001 | 01:08 AM
emax02's Avatar
If it is anything like the oem supension you would remove it like this: You have to put wrench on the bolt on the very top of the strut, then you get a vise grip and attach it to flat piece of metal at the very top of the strut. While holding the vise grip firm turn the nut{14mm on mine} counter clock wise with your wrenchYou may need to use a vice to hold the strut still}. With enough force you should get the nut to break loose and then it should unscrew pretty easaly. REMEMBER to compress your spring before doing this with a spring compressor! So after you get the bolt off the top of the strut remove the strut tower insulator{the piece with the 2 Strut tower bolts sticking out}, then remove the rest of the harware and do the reverse to reinstall. But like I said before, these directions are for a oem setup so they may not apply for your cattman coilovers.
Old Nov 25, 2001 | 07:40 AM
MAC's Avatar
MAC
Re: how do i put this new coilover together???
Did the sleeve break, or did the strut break?
Did you get the replacement parts from Brian? Why didn't he give you some instructions?
If you still need help, email me and I'll help you.
mingc@bellsouth.net
later.
ming
Old Nov 25, 2001 | 10:08 AM
max'n out's Avatar
Yeah what broke exactly?
Old Nov 25, 2001 | 11:09 AM
98MAX's Avatar
If you are familiar with the coilovers, at the top of the shock where the bronze looking piece is welded on(this is what goes threw the strut tower). The weld broke. I cant see how it held as long as it did. WTF man high dollars for this too man sheot.
Old Nov 25, 2001 | 12:30 PM
max'n out's Avatar
I have the cattman coilovers and I'm not sure what you are talking about...are these gen1's or 2's?
Old Nov 25, 2001 | 12:50 PM
Sprint's Avatar
gen 1
Old Nov 25, 2001 | 01:15 PM
98MAX's Avatar
OK, I can finally end the mass confusion(LOL). Got it together. Man what a pain in the azz. The next time this happens, the car is gone! Too much of a pain in the azz for me. Thank for your guys help.
Old Nov 25, 2001 | 03:21 PM
I30CeFiRo's Avatar
Yep, I had the same problem with the Cattmans where the strut rod snapped at the weld. You'd think for that much money you'd get a more reliable product huh?
t6378tp
Sep 29, 2018 04:27 PM
BkGreen97
Apr 2, 2016 05:47 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
A32goldylocks
Sep 14, 2015 06:49 PM
Violator
Sep 9, 2015 10:14 AM
