Tech Question, please help
Old Dec 5, 2001 | 11:03 AM
black019's Avatar
Ok heres my problem, over the past few weeks I have noticed a few things about my car. First of all when I first start the car and drive, I notice a clicking-type noise. To me it actually sounds like more of a vibrating sort of noise but it comes from the front passenger side of the car. It happens on hard acceleration regardless of whether or not I am turning. People have told me it's the CV joint but I'm not exactly positive. I checked for grease in that area to confirm but I havent found any.
Now I have noticed something else about the car more recently. Whenever I get above about 55-60 mph the car gets real bumpy like Im driving on a gravel road almost. Past 75 it gets better but the vibration still is there but sporadicly (sp?)
Now I have only two guesses, CV joint or wheel bearing. What do you guys think? More importantly, what are the consequences of driving on it?
Old Dec 5, 2001 | 11:18 AM
magnum's Avatar
YAH THe shaking would be due to an alignment problem. as for the noise, i have the same thing, its usually when im around 2k-2.5k rpms, and its more like a buzzing, but i didnt get worried about it cuz my saab did the same thing
Old Dec 5, 2001 | 11:46 AM
DanNY's Avatar
Ad·min·is·tra·tor
keep in mind...
shaking and vibrations - wheel balance or tire/rim out of round
pulling or uneven tire wear - alignment
Old Dec 5, 2001 | 02:38 PM
magnum's Avatar
Originally posted by DanNY
keep in mind...
i stand corrected
Old Dec 5, 2001 | 02:46 PM
dwapenyi's Avatar
Re: Tech Question, please help
Rotate your tires. If the sound moves to the back, then congrats, your problem is relatively simple. It's either your wheels or tires. They could have gone bad because of wheel balance, wheel alignment, or bent rim. If the noise stays in the front after your rotation, then you've got bigger problems, like bearing, CV joint etc
DW
Old Dec 6, 2001 | 03:59 PM
black019's Avatar
ok so I've noticed that the side in question is leaking some sort of fluid. does that help narrow down the problem for sure? It looks like some sort of oil type fluid...
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Redfox
Sep 28, 2015 10:41 AM
REDinLV
Sep 28, 2015 12:31 AM
Socalstillen
Sep 26, 2015 12:01 PM
