Ugg..replace the muffler and I still have a rattle, it's the Y-pipe
Old Dec 13, 2001 | 09:05 AM
Dave B's Avatar
Not DAVEB the parts guy
For the past 8 months I've had a exhaust rattle that has gotten progressively worse. The rattle/buzz only occurs from 2000-2500 rpms depending on gear and load. With the windows rolled up it's no big deal, but with the windows down and near a object, the noise is very embarassing. The noise comes straight out of the muffler. At first I thought it was a brick in the RT cat that had come loose. I swapped in the stock cat and the noise was slightly quieter, but was still there so I swapped the RT cat back in (strike one, not the cat). A few months ago I got a Stillen B-pipe to replace my Courtesy B-pipe. Maybe the Courtesy B-pipe resonator had rusted out and caused the rattle? Nope, the non-resonated Stillen B-pipe made the rattle louder (strike two). I moved my train of thought to the muffler. Maybe a baffle had become dislodged a bit and was resonating under certain rpms. I get hold of a nice 99 muffler and the rattle is still there (strike three). Since I've replaced or swapped out everything on my exhaust EXCEPT for the Y-pipe since the rattle, my thoughts are it's the Y-pipe flex section.
Last night I looked into exit pipe of the Y-pipe while shining a flashlight on the outside of the flex section to see if light came thru. I couldn't see light so I doubt it's leaking. I didn't think it was leaking either because the sound is a rattle, not a hiss or "tapping" like a leak causes. I think something in flex pipe housing has become loose and rattles at certain rpms. I couldn't see anything that looked loose. I squeezed the flex section and it felt a little soft and "crunchy". I guess I'll have to bite the bullet and possibly get a new y-pipe. My y-pipe is over 2.5 years old, seen 3 salty winters, and is one the orignal Stillen pipes with the equal length tubes. I might just get the Warpspeed non-mandrel Y-pipe. I've seen GuidoSST's non-mandrel Y-pipe and I have little doubt the non-mandrel flows just as well as the mandrel. Warpspeed uses a special bending process that doesn't seem to kink nor restrict the bends. It's very smooth. $200 is all I want to spend because I won't be keeping this car anymore than another 1 year.
What have I learned? The stock muffler isn't prone to rusting out like some other imports. The RT car is less restrictive simply because more noise was noted. Trouble shooting exhausts is a big pain in the aZZ.
Anyone had this problem before?
Dave
Old Dec 13, 2001 | 09:16 AM
UMD_MaxSE's Avatar
Got Bent?
what kind of y-pipe?
Old Dec 13, 2001 | 09:27 AM
Sprint's Avatar
cat bracket?
Old Dec 13, 2001 | 11:38 AM
96sleeper's Avatar
check cat brackets and heat shields
I also had the same problem and it turned out to be the heat shields rattling back around the b-pipe. Just a thought before you have to spend money.
Old Dec 13, 2001 | 11:47 AM
Synki's Avatar
Originally posted by SprintMax
cat bracket?
That was the prob w/ mine and it gave me a rattle feeling under low acceleration. After i swapped it out w/ hollowed out cat, i have no noises nor vibrations.
Old Dec 13, 2001 | 11:58 AM
Sprint's Avatar
I wonder who gave you that idea?
Old Dec 13, 2001 | 12:17 PM
Synki's Avatar
Thank you Do... Darren.
Old Dec 13, 2001 | 12:18 PM
Sprint's Avatar
Old Dec 13, 2001 | 12:22 PM
ToYLeT902's Avatar
JET Speed Lab
Old Dec 13, 2001 | 12:23 PM
Sprint's Avatar
Originally posted by ToYLeT902
Old Dec 13, 2001 | 01:05 PM
ericdwong's Avatar
Re: Ugg..replace the muffler and I still have a rattle, it's the Y-pipe
Originally posted by Dave B
...because I won't be keeping this car anymore than another 1 year.
Why not? And what are you going to replace it with?
Old Dec 13, 2001 | 01:07 PM
Dave B's Avatar
I'll check the cat bracket and heatshield towards the rear of the B-pipe. I don't have a heatshield above the cat so that's not a problem. By cat bracket, do you mean the hanger bracket that supports the rear of the Y-pipe where it connects to the cat? Was anyone's rattling caused by sound reverberations and not necessarily metal to metal contact?
Dave
Old Dec 13, 2001 | 01:09 PM
Jeff92se's Avatar
I'm needing a caw
Look for sooty spots along the flex section. If you see them, that means the flex is probably leaking. I would try to wrap the flex w/ some header wrap to see if it quiets it down
user 11122324
42
Jul 18, 2022 03:35 PM
Quickywd01
Sep 21, 2016 09:36 PM
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
