hardcore brake grinding....
Old Oct 1, 2010 | 04:50 PM
panda_1's Avatar
need your opinions...... but before i start some info, im running the blehmco bbk and i recently swapped over for iron calipers instead of aluminum, new rotors, pads and fresh fluid.... ever since i have a naaasssttyyy grinding, the only thing i can think off is that there is a clearance issue with the iron calipers, i am awaiting a confirm from matt but i need intel....
thanks guys.......
Old Oct 1, 2010 | 04:56 PM
Stormzusmc's Avatar
take your wheel off and look....?
Old Oct 1, 2010 | 04:57 PM
panda_1's Avatar
already did and theres no griding when i do, i got all up n dirty peek a booing to see if theres a clearance issue and i see non, so im stumped. im about to put the old calipers on and see if it stops, just dont want to have to rebleed if i can avoid it.
Old Oct 1, 2010 | 07:53 PM
Stormzusmc's Avatar
does your wheel wobble?
Old Oct 2, 2010 | 01:50 PM
panda_1's Avatar
the driver fron has a bad bearing, however the noise is coming from both sides and with the previous calipers it never made the noise, so ive kind of ruled that out.
Old Oct 8, 2010 | 11:36 AM
RustyMax's Avatar
I would say it's a clearance issue, was the grinding when braking or constant?
Old Oct 9, 2010 | 02:13 PM
Hellrot318is's Avatar
Why drive around with a bad bearing? If you have a bad bearing, they make noise as you describe. Replace it.
Old Oct 9, 2010 | 11:41 PM
asand1's Avatar
Your caliper is rubbing your wheel.
Old Oct 21, 2010 | 08:51 PM
MaxiNone's Avatar
i have the same problem randomly and i know its not the wheels rubbing the caliper because its been doing it after 2 sets of wheels and neither set show rubbing wear on the back side of the wheels. i would say maybe a back caliper because of the wear on the brake pads. so i would say check the calipers and brake pads...
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
