Agrrhh RUST!!
Old Nov 29, 2010 | 05:18 PM
NJ3ndri's Avatar
Agrrhh RUST!!
So im pretty sure we know of the infamous rust loving lower rad support....the piece where the front of the cross member bolts on to...well both of those bolts are no longer supporting the cross member due to that ugly rust on my A32 max......does anyone have a max for parts i need that lower piece asap. or a solution which would involve just cutting and welding some new metal in there
Old Nov 29, 2010 | 05:38 PM
njmaxseltd's Avatar
Order a new O.E. part online. Have a body shop replace it or look at a few well documented threads on here and see if you'd like to tackle it yourself.
Old Nov 30, 2010 | 01:10 PM
Quickywd01's Avatar
Watch out with those aftermarket radiator supports as some people say they don't last long. I've seen someone weld flat stock in there to repair theirs. Looked like the best solution. There's a thread on here somewhere with pics.
Old Nov 30, 2010 | 07:33 PM
NJ3ndri's Avatar
i actually work at a body shop. lol its a pain in the *** the do the whole rad support cuz theres so many pinch welds. and aftermarket supports dont line up sometimes and they turn into a project/nightmare....i went to home depot and bought some 90degree angled steel plate. im gonna cut the center of the lower rad support and weld this piece in. shape kinda matches it pretty good. ....i can feel my motor starting to rock n pull everytime i take off from first o_0...****
Old Dec 5, 2010 | 12:12 PM
Quickywd01's Avatar
That's exactly what I meant. I think this will be better than removing the whole rad. support. BTW the person that I mentioned: http://forums.maxima.org/7821076-post481.html
Old Dec 5, 2010 | 12:57 PM
Stormzusmc's Avatar
find a local shop that specializes in frames and restoration....i was quoted around 2-250 to fix this..
Old Dec 5, 2010 | 05:39 PM
96nismoSE's Avatar
which shop? haha i need it done but dont want to mess with it myself
Old Dec 6, 2010 | 10:50 AM
IanC83's Avatar
I just had that done to my car a month ago. As you know if you work in a bodyshop its not easy but I would go with an OEM support. My bodyshop got an OEM one for around $180. After it was installed I found a website that sells all OEM nissan parts www.nissanpartsconnection.com. They are selling the same part for $140.00
Old Dec 6, 2010 | 06:32 PM
NJ3ndri's Avatar
yea usually its a pain in the *** to get things aligned with aftermarket stuff. but its a pain doing these because they are welded and you have to drill out the welds. some cars are bolt on..this one unfortunately isnt. but if anyone is looking for oem stuff they have them at http://courtesyparts.com/ . i dont think itll be too hard to just fix that lower piece tho. ill try to get some pics up after i get to mine...if i remember to take any (thats usually the last thing on my mind)
Old Dec 6, 2010 | 06:33 PM
NJ3ndri's Avatar
http://www.courtesyparts.com/maxima-...1897_1900.html
Old Dec 7, 2010 | 05:17 PM
sascuderi's Avatar
Mine had a slight degree of surface rust (garage kept since new). I just repainted and applied a layer of clear caulk along the entire surface of the rail. Kind of just acts like a barrier to the wet.
Old Dec 11, 2010 | 11:52 AM
ampire's Avatar
Most people just weld a big bar across it. http://forums.maxima.org/7756830-post431.html
http://forums.maxima.org/supercharge...-build-13.html
Turbonut
46
Oct 21, 2015 08:28 PM
RealityCheck
Oct 2, 2015 06:34 PM
uttadms31
Sep 30, 2015 05:24 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
