What's the difference? Ethanol and MTBE
Old Dec 22, 2001 | 01:57 PM
DOM's Avatar
DOM
I was going to the pump earlier on today to get some gas and I noticed that most gas pumps have MTBE. When I went to Unocal 76, they have Ethanol as opposed to MTBE. What are the differences between the two for my Maxima.
Old Dec 22, 2001 | 02:08 PM
bmfjeep's Avatar
Gasoline producers are required to add a fuel oxygenate to reformulated gasoline to reduce air pollution, especially carbon monoxide. MTBE is the most common fuel oxygenate used in more than 80 percent of oxygenated fuels. MTBE is credited with contributing to significant reductions in carbon monoxide and ozone levels in many of these areas. Ethanol is used also but made from corn.
MTBE in your water can kill you ( it takes a while, usually cancer )and in the last 10 years or so has become a major issue for the epa due to those underground storage tanks which seemed to leak a lot, the ethanol probably not.
Dallas
Old Dec 22, 2001 | 02:11 PM
Jon91SE's Avatar
Pusssseeeehhhh
DOM your sig scares me
Old Dec 22, 2001 | 02:15 PM
Greg's2kGLE's Avatar
Dallas
I saw a segment from 60 minutes (i think that's what it was) on MTBE. It took place in some town out west, and a gas station had been using MTBE and a tank started leaking. Contaiminating water and people started getting sick from it. It was pretty bad. They put it in for emmissions purposes.
Old Dec 22, 2001 | 02:24 PM
DOM's Avatar
DOM
Okay thanks for some of the background stuff but what i am trying to ask for is what is the difference between MTBE or Ethanol IN my car. Why does 76 prefer ethanol over MTBE? Performance wise, which is better? Better gas mileage?
Old Dec 22, 2001 | 02:26 PM
Well both will probably give you worse gas mileage because they are putting additives in. Try and search the internet, I am sure somewhere they have a comparison.
Old Dec 22, 2001 | 03:02 PM
bmfjeep's Avatar
The FED's don't mandate which has to be used. The states which are required to use oxygenated fuels usually decide what they want used. Seems like Illinois is big into ethanol and I think Minnesota, probably the states with the most corn. I think Canada banned MTBE outright several years ago, it used to be produced by the Ethyl company but when people started getting sick......you can guess the rest. Ethyl spun off that subsidiary, one of my friends worked for them which is why I guess I even remember all of it.
Dallas
Old Dec 22, 2001 | 03:22 PM
NoHalo's Avatar
Re: What's the difference? Ethanol and MTBE
Ethanol is definitely the better of the two. You could literally run your engine on ethanol if you had too ( it would end up destroying it though). It also helps support our corn farmers...
Here's some more info on ethanol:
http://www.iowacorn.org/em.htm
Wouldn't ya know it's a website by Iowa corn farmers...
76 gas is also known for selling top quality gas. I don't think you can go wrong with them.
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Pied
Sep 26, 2015 03:29 PM
