View Poll Results: Have you experinced new leaks after switching to syn?
Yes, I have.
31.25%
No, I havent.
68.75%
Voters: 16. You may not vote on this poll
Has switching to syn caused you to leak?
Old Feb 23, 2012 | 09:21 AM
asand1's Avatar
I will open this poll thread with a qoute posted by another member, do not know the OP. I cannot attest to the accuracy of these claims, but they sound legit. At any rate it sounds like switching to syn CAN result in leaking for whatever reason.
Have you sprung new leaks immediately after switching to synthetic oil?
We all know the anecdotal evidence, please dont post your experiences or opinions, just the results of you personally switching.
I would be a liar if I told you that switching over to synthetics could not possibly cause leaks around seals and gaskets. However, anyone who gives you the impression that this is the most likely outcome is either misinformed or lying themselves. Here is the whole story in easy to understand terms.
Back in the 70's and early 80's some synthetics were not blended correctly and caused engine oil leakage in some vehicles. Basically, the problem is that synthetic basestocks do not react the same way with seals and gaskets that petroleum oils do. PAO basestocks (the most common synthetic basestocks) tend to cause seal shrinkage. If the proper additives are not used, seals will shrink when using a PAO based oil, and leakage will occur.
Fortunately, oil manufacturers learned their lesson and reformulated their oil to contain the proper additive package which helps condition seals and gaskets to maintain their flexibility while also maintaining proper seal swell. In fact, the reformulation in most cases provides for better seal conditioning than most petroleum oils these days. Nevertheless, there is still a possibility of leakage if making the switch to synthetic - but only under certain conditions. Please allow me to elaborate a little bit.
Any of you who are considering a switch to synthetic oils probably know by now that petroleum oils do not necessarily keep your engine squeaky clean. Well, if you own an older vehicle (late 80's to very early 90's) it's possible that you have leaks in your engine already. Now, before you all string me up by my toe nails telling me there's never been a drop of oil that leaked from your engine, let me explain myself.
On older vehicles which have been lubricated with petroleum oils, seals and gaskets can begin to dry and crack. The reason you don't actually see leaks is because petroleum oils tend to burn off and leave sludge, grime and varnish on the inside of your engine. That's simply the nature of a petroleum oil's make-up. Now, conventional petroleum oils are not very discriminatory about where they leave those deposits. Therefore, some of the deposits end up around your seals and gaskets which actually plugs up the gaps which would have resulted in oil leaks.
"Well," you say, "I guess all of those synthetic oil nay-sayers were right. If petroleum oils keep my engine from leaking and synthetic oils might actually make it leak, I guess petroleum is the better oil."
Not even close. The fact is, it's a result of using petroleum oil instead of a high quality synthetic that resulted in dry and cracking seals & gaskets in the first place. As I mentioned earlier, synthetic oils now contain special additives which maintain proper seal swell and keep them flexible so that seals and gaskets don't dry and crack in the first place. So, for those people who use synthetic oils from the start (after a 3,000 to 5,000 mile break-in period), the problem never becomes an issue.
Of course, the next obvious question is, "If synthetics have those special additives, why might they cause leaks in an older engine? Why don't they correct the problem?"
Believe it or not, I've got an answer for that too. The "problem" is that there are also other additives that give a synthetic oil its detergency properties. In other words, there's other stuff in high quality synthetic oil which tends to clean out the sludge and deposits left behind by petroleum oils. Once these deposits are gone, the gaps around seals and gaskets become exposed and the oil might begin to leak in these areas.
However, there is good news. It's likely that the additives we discussed earlier will begin to lubricate the seals causing them to become more flexible and leading to seal swell which may plug those gaps over time. The only drawback is that there's no way of knowing how long it may take for this to occur or if the seals are already too far gone to be salvaged. If the problem doesn't correct itself, it is likely that the seals and gaskets would have to be replaced to prevent further oil leakage.
So, to wrap up. Petroleum oils can screw up your seals and gaskets and then fill the holes with gunk and deposits to cover their tracks. Synthetic oils come in and begin to clean up the place. Once it's clean, the holes might be exposed (if there were any) and the oil begins to leak. After a while (no way to know how long) the synthetic may be able to help the seals and gaskets regain their composure and stop the leaks
One very important point to keep in mind is that if 100 cars were put in front of you (all older vehicles lubricated with petroleum oil), the switch to synthetic would probably cause less than five or 10 of them to leak. The odds are definitely in your favor.
As is the case with most things, you tend to hear much more about the horror stories than you do about the success stories. I have spoken with numerous people who have made the switch successfully without ever having a leak. In fact, I personally have converted two older vehicles without even a hint of a problem.
Unfortunately, those who have had problems start screaming and yelling to everyone they know (with the best intentions) that synthetics will screw up your engine. Just take it with a grain of salt and you and your car will be fine.
NOTE: If you have a newer vehicle that has very few miles on it (say newer than 94 and fewer than 50,000 miles on it) and it begins to leak after switching from petroleum to synthetic oil, there may have been a manufacturer defect. Unless the manufacturer or dealer can prove that the synthetic oil caused the leakage, they are required, by law, to repair the vehicle under warranty (if you are still under warranty).
Old Feb 23, 2012 | 09:26 AM
asand1's Avatar
Post your Gen, mileage at time of switch, and result. Please keep discussion to a minimum.
Old Feb 23, 2012 | 05:07 PM
BenL's Avatar
4th Gen (1996)
140,000 miles @ time of switch (now at 149,000)
No leaks because of switching, lower portion of motor still has the factory seals/silicone.
Old Feb 23, 2012 | 07:03 PM
discobiscuit's Avatar
4th Gen Maxima switched to Syn last week at 144,000 so it is too early to tell. Will keep everyone posted
Old Feb 23, 2012 | 10:21 PM
DAlastDON's Avatar
6.5gen. Switched at 20k miles. Currently have 60k miles. No oil leak or consumption problems.
Old Feb 24, 2012 | 06:29 AM
boneebone's Avatar
1999 4th Gen, 126xxx miles, Supercharged, no leaks.
Old Feb 24, 2012 | 07:40 AM
NismoMax80's Avatar
SuPeRmOd
Invalid question.
Impossible.
If you think this has happened this is what actually happened:
You already had a "leak" but caked up filth/old oil masked it. Synthetic cleaned the gunk away and revealed your already existing leak.
If you would have used synthetic or other high quality oil, it would have stayed cleaned and seals conditioned. Now your seals are old, dry, cracked, and leak.
Replace seals and use high quality oil or synthetic.
Old Feb 24, 2012 | 09:20 AM
asand1's Avatar
Originally Posted by NismoMax80
Invalid question.
Impossible.
I didn't ask your opinion. In fact I asked you to keep it to your self.
Old Feb 24, 2012 | 10:32 AM
2damax's Avatar
NismoMax, I agree with you 100%. However, OP does not want to hear the opinion (even if it is FACT).
5.5 gen w/ 116k. Switched to syn at 65k. No leaks. But damn I burn enough.
Old Feb 24, 2012 | 11:56 AM
asand1's Avatar
I am begining to lean this way.
This is what I doubt, and the reason for the poll.
I bpought my car with over 260K miles so thats not a realistic expectation.
At my mileage, with a beautifully running and clean engine, why should I? I change at 3K with cheap oil at $2.40/qt.
The idea here is not that the oil is responsible, but that the owner/mech, by neglect and the act of switching over to synthetic, caused the situation. If I really thought I needed syn, and I dont in my climate here, I would first do a complete engine-out reseal. In a 5 gen or later, I might just take my chances.
Old Feb 24, 2012 | 12:32 PM
T_Behr904's Avatar
Being rude to a moderator won't get you very far. You have been here long enough to know this.
That being said, if you switch a high mileage engine over to synthetic, it will start to develop leaks.
Old Feb 24, 2012 | 02:34 PM
asand1's Avatar
Didn't intend to be rude. However, when a Mod posts a noob worthy reply I will let him know it was not needed nor wanted.
I mean it was all right there in the first post. As far as the dissertation, he just regurgitated what was already quoted there, so what was the point?
If I get banned for that then I don't think I need to be here.
Old Feb 24, 2012 | 03:47 PM
JDM BOIIA32's Avatar
98 i30t switched @ 165k
Burns very little
Old Feb 24, 2012 | 04:59 PM
asand1's Avatar
This is what I'm saying. While it is not the synthetic oils fault, it is still cause and affect regardless of how or why. I am trying to determine the degree of this "truism".
Old Feb 24, 2012 | 05:15 PM
chrome91's Avatar
my 3rd gen had Mobil1 in it from new i think and i used Castrol Synthetic in it til it died, even then it just left the odd drips that a 429,000km car gets. i run Royal Purple in the truck and Supra, synthetic oil causing leaks is a load of crap
Old Feb 24, 2012 | 05:18 PM
Originally Posted by chrome91
i run Royal Purple in the truck and Supra. Royal purple is a load of crap
Sorry, I had to fix that.
I've been running synthetic in my 5.5 since I got it and I burn no oil.
Old Feb 26, 2012 | 11:22 AM
maxed_out_99's Avatar
4th gen I switched when I bought it at 177k no leaks it only started to leak at the valve covers at 189k when I put a 1/2 a quart of trans fluid in it
Old Feb 26, 2012 | 02:46 PM
NismoMax80's Avatar
SuPeRmOd
noob response?
Yet you are using noob logic to determine cause and "affect" which doesn't even make sense.
Trying to determine if the effect of leaking oil is caused by switching to syn from a few random responses proves nothing. I simply stated facts. Afterwards I read the info you copied from somewhere. Regardless this is an open forum that no one can dictate if someone is permitted to respond.
So sorry to have tried to help.
here educate yourself on this site: bobistheoilguy.com
Old Feb 26, 2012 | 05:10 PM
asand1's Avatar
I clearly asked for no opinions, theories, or stories. You went ahead and did it anyway, helping noone in the process. That equals noob. You are free to post here, but as a mod you more than anyone should understand the importance of staying on topic and contributing to the thread.
Ii has been said that only horror stories get reported and most people have no issues and are never heard from. I only wanted to see if that were true.., out of curiousity.
Personally I don't intend to run synthetic because it wouldn't benefit me personally.
Old Feb 26, 2012 | 07:20 PM
asand1's Avatar
You already had a "leak" but caked up filth/old oil masked it. Synthetic cleaned the gunk away and revealed your already existing leak. .
You said it yourself here. And I agree with you. The oil doesn't "ruin" engines, and isn't responsible for the leaking. I just want to see how common this issue really is.
Old Feb 29, 2012 | 04:25 PM
dondadah88's Avatar
i switched to syn at 191,000 i'm at 216,000 and no oil leaks
2001 nissan maxima auto
Old Feb 29, 2012 | 07:09 PM
Tex's Avatar
Tex
i had no leaks, 80k miles, switched dino to mobile 1 synth
Old Mar 11, 2012 | 09:54 PM
FlipCpt45's Avatar
My 5th gen (VQ30DE-K w/ < 74k) switched to Mobile 1 5w30 when I got inherited it w/ 21k in 2006. I don't remember any problems with it.
My 4th gen (VQ30DE with < 65k) has the semi-syn stuff or w.e and it leaks oil (but common problem on 96's it seems)
The 350z (VQ35HR w/ 32k) has German Castrol 0w30 in it. I've read some threads on Bobtheoilguy and various 350z / G35 forums that the GC is a thicker oil compared to Mobil 1 and the that the VQ35DE doesn't burn it.. or as badly.
Old Mar 11, 2012 | 10:07 PM
ShocknAwe's Avatar
I switched a high mileage(probably 160k cant remember exactly) car to syn and no leaks. Then again I take care of my car. I lean in the direction of a leak already being present and the new oil simply brought it out.
Old Mar 11, 2012 | 10:11 PM
VQPOWERGLE's Avatar
i dont remember when it was switched to but it leaked before the switch. 4th gen 1998 se 5 spd.
Old Mar 12, 2012 | 12:39 AM
KT3MaxSE's Avatar
Switched @ 80K on '00 DEK and @ 46K on '05 Altima 3.5...No leaks in either to this day...
Old Apr 30, 2014 | 12:23 PM
tech_auto's Avatar
I had a minor leak. When I used a high mileage part synthetic, the leak is much worse.
Old Apr 30, 2014 | 01:07 PM
tosheto's Avatar
I switched to full synthetic at 185k on my 01 Maxima. 10k later, there is not one drop of oil leaking.
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
johnaschon
Sep 14, 2015 04:29 PM
dcam0326
Sep 7, 2015 07:26 AM
