FP and EGT Guage Install questions
I just ordered AutoMeter FP and EGT guages and had some install questions...
FP: I'm assuming that the guage comes with a sender that "Tee's" into a fuel line somewhere. Where is that? Near the fuel filter?
EGT: Does the guage kit (ordered from summitracing.com) come with the sensor that needs to be installed into the y-pipe? Where does that sensor get installed, after two pipes from the front and rear bank come together?
Any other tips or hints? Anyone have any write-ups?
Re: FP and EGT Guage Install questions
oh btw... i put my sender and FPSS between the Fuel Filter and the Connection to the engine
i think..you put the probe in the rear bank y pipe coming down from the engine..
Re: Re: FP and EGT Guage Install questions
Originally posted by SprintMax
depends.. some kits come with probes some do note.. depends on which one you ordred.. if you didn't pay more than $160 .. then you don't have the probe kit
i think..
Why the rear bank? Because it would go lean first?
Originally posted by theblue
somebody else is watching closly here
Email (or PM) me with your work email and phone #.
Re: Re: Re: FP and EGT Guage Install questions
Well, I didn't pay $160...I paid like $70 something. So I assume I have to puy the probe seperatly now. Just the AutoMeter one, or is there a different one that would be better?
You will need to buy some fittings to install the fp sender. I have mine after the fuel filter and before the stock FPR.
Your EGT probably didn't come with a probe.
Check here for the probe.
http://www.autometer.com/hp/2001_cat...sories/90.html
Originally posted by Ramius83
Sprint, is it ok for the probe to be installed in the y-pipe where the two exhaust down-folds meet together?
Sorry to bring up an old thread guys, are all these probs the same? I am assuming that the ATM-5249 probe will work fine. Am I correct?
http://store.summitracing.com/defaul...rchtype%3Decat
Thanks.
Thanks.
Thanks.
Thanks.
Also, looking at the sender for the FPSS and FP guage they look like they do the same thing?
Can I just tap the FP guage wires into those coming from the FP Sensor for the FPSS?
This: http://www.rit.edu/~ejjfac/maxima/NOS/nos2.jpg
Thanks again.
Thanks again.
Thanks again.
Thanks again.
the FPSS has two connections.. ground from the Solenoid and Ground going to the other Solenoid.. i can't remember which to which but its in the manual.. but its only ground connections..
the Sender has three connections i think.. and one is ground.. DO NOT.. use that ground with the FPSS.. oh and the FPSS .. even though Matt will get mad.. me, nor synki has hooked it up.. actually I think Matt is the only one running NOS who has actually connected his FPSS
its a b!tch to tune the FPSS.. if you want instructions from that.. i can tell you.. but its going to take some time to write up.. i gotta pull what Matt told me from memory..
Seriously Matt .. you need to buy like 3 FPSS .. tune them.. and sell them to ppl for a core..
I should just quit posting and PM you my questions directly. Thanks agian.
keep posting .. its so others can learn also.. they might have simular questions.. and my pm's won't show up in the search function
No..
No..
I plan on installing the FPSS, I don't really care that its going to be a pain to tune. I figured I'd pick up a mechanical FP guage as well and put it into the engine bay like Matt did. I figure that would make tuning the FPSS a lot easier.
Bummer. Can adding all these T's and sensors to the fuel line drop pressure?
wait till you see the instructions to tune it ..
.. it involves multiple runs with NOS.. disconnected solenoids.. connected solenoids.. test light.. pulling over on the highway.. sheesh..
the fuel flare jet will determine the PSI you run at.. the .042 jet the kit somes with is adequate from 40 - 70 shot.. the Sensors and and all that stuff won't do anything to the pressure but monitor it..
ha..
ha..
Do you have the instructions somewhere? That would rock.
no .. i can ither..
a) type them up from memory..
b) link matt to this thread and hope he will type them up..
I will do b.. but if no response i will do a
Yeah, I know it will be a *****, but I think it will be worth it. The last thing I want to do is screw up my engine like some people aroud here have done.
no .. i can ither..
no .. i can ither..
95Maxi
Aug 25, 2015 08:01 PM
