Transmission Problem?
Old Jan 7, 2002 | 06:02 PM
90Max
I have a '90 Max with automatic transmission. I have recently experienced three incidents where I hit the gas and the engine revs as if in netural but the gear does not engage. On two occasions (starting from a dead stop at a stopsign) the gear quickly catches. On one occasion, while on a highway, I had to pop the shift into neutral and then back to drive to get the gear to engage. Othewise, the transmission shifts gears very smoothly.
I recently had a transmission fluid leak (some kind of cracked seal)and the dealer repaired and power flushed the fluid. However, the third incident on the highway occured after this repair. I've never owned a car with transmission problems so I don't know much about this.
Any ideas what may be wrong and what to do? Thanks
Old Jan 7, 2002 | 06:33 PM
brubenstein's Avatar
If you have over 100k miles, and that was the first time the trans was flushed, you need an new/rebuilt transmission. When you had the leak the fluid level probably wound up low for a while which is real bad for a trans. 3rd gen trans are not the most robust devices ever made.
Old Jan 7, 2002 | 06:41 PM
90Max
I have had the tranmsission fluid flushed regularly (although not religiously over the years). Any idea what it costs to rebuild or replace a transmission?
Old Jan 7, 2002 | 07:03 PM
eric93SE's Avatar
Everyone is always so anxious to get a rebuilt tranny . It could be something simple like the solenoid pack thats gone bad. the solenoid pack is only a little over $100 and can be done with out removing the tranny. I'm not saying that this is definitly the prob, but there are lots of sensors and **** that could cause the prob. BTW there are problems w/nissan's solenoid pack for our third gen. and could very well be your prob.
If you dont have the experience to diagnose the tranny yourself. then go to a well reputable tranny repair shop, but not nissan b/c they only replace the entire tranny (dumb A!SSes). And see what they can find
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
