Help with residue after debadge?
Old Sep 14, 2012 | 07:33 AM
99MaxLoaded's Avatar
So i debadged my trunk awhile ago, and there has always been a very slight amount of residue from the glue still on the trunk, and i figured its about time to get that off of there. I searched around but couldn't really find a good answer to this question :/
How do i get it off? Do i use a product? And will said product damage the paint on the trunk (which seems to be somewhat coarse, and not smooth anyway)
Thanks for any answers, here is a pic of the trunk for refference, you cant see it clearly, but there is residue where the "MAXIMA" lettering was -
Old Sep 14, 2012 | 07:40 AM
GGENIUS's Avatar
wd40 will make it gel up. or an eraser wheel will take it right off.
Old Sep 14, 2012 | 07:42 AM
What do you mean by gel up? like it will be able to be just rubbed off?
Old Sep 14, 2012 | 08:20 AM
Amerikaner83's Avatar
gel up, meaning it will turn the sticky stuff into booger-like stuff, which wipes right off
Old Sep 14, 2012 | 09:24 AM
Toxic!'s Avatar
This is what I'm scared of. I want to de-badge my 5th gen but I don't want it to be left with a tan outline of the "MAXIMA" emblem. Let me know what works to get it off!
Old Sep 14, 2012 | 09:56 AM
Ill try the wd40, and report back on results (:
Old Sep 14, 2012 | 07:18 PM
GGENIUS's Avatar
i usually use a plastic scraper of some sort with the wd40. and yes, no matter what you do you will see the tan lines from the badges. unless you repaint.
Old Sep 14, 2012 | 07:46 PM
T_Behr904's Avatar
If the paint is in good shape it will buff out.
Old Sep 14, 2012 | 07:59 PM
RA121625's Avatar
This.
Try some paint polish with a buffing pad, that should get it right out.
Old Sep 14, 2012 | 08:10 PM
nismomaxgtr18's Avatar
Goo Gone.
Old Sep 14, 2012 | 08:45 PM
AznRyan's Avatar
Freshly squeezed badger milk. It might work.
(Disclaimer - Badger milk would never work, regardless of how freshly squeezed it is. You should never put badger milk on your car's exterior)
Old Sep 15, 2012 | 06:20 AM
GGENIUS's Avatar
Originally Posted by Tyutyunnik
This.
i was trying to give the guy a realistic answer, not some bs that i know doesnt work half the time from experience. yes buffing will work if your tan lines are slight. does not always work at all.
Old Sep 16, 2012 | 07:22 AM
AllentownMaxima's Avatar
I had this problem, but I effd up trying to scrape it off with a razor smfh now I got the tan lines and scratches
Old Sep 16, 2012 | 07:50 AM
mrjasonlyrics's Avatar
"I" used a heat gun soften the glue and wiped it off with a cloth, then used reducer and clean it completely then used a 3M compound and buffed any scratches left behind while attempting to remove the glue
Old Sep 16, 2012 | 08:28 AM
T_Behr904's Avatar
Brake cleaner also works well removing old left over glue.
Old Sep 16, 2012 | 08:33 AM
Yes brake cleaner works well. I actually misunderstood and thought you meant brake fluid. LOL
RinconI30
Jun 11, 2016 08:25 PM
jc53
Oct 6, 2015 06:00 AM
MaximaRaj
27
Oct 2, 2015 07:31 AM
mpbclutch33
Aug 25, 2015 06:23 AM
areX
Feb 12, 2001 11:29 PM
