100 octane, what a gas...
Old Jan 8, 2002 | 06:19 PM
MONTARABOB's Avatar
Pulled into a 76 gas station in San Jose,CA and see the standard 87,89,91 nozzle then I notice the other side of the pump, “100 OCTANE RACING GAS”, unleaded. Couldn’t pass this one up. !! Paid 4.09 gallon (ouch) X 4 then added 8gl 91. Talk about fire-in-the-hole! Should be ‘bout 95 octane?? Any of you ever run this stuff at full strength on a stock VQ30? Will octane in a bottle be a better way to go? I shouldn’t feel so bad bout $$ ‘caus the Saleen SC next to me said he fills-up at this $ at least once a week.
Old Jan 8, 2002 | 06:26 PM
Jeff92se's Avatar
I'm needing a caw
Probably will not do anything as your engine is designed for XX octane anyway. Anymore is just a waste
Old Jan 8, 2002 | 07:13 PM
mzmtg's Avatar
Minister of Silly Walks
Total waste of your money. If the car wasnt designed for it, it can actually hurt performance.
Old Jan 8, 2002 | 07:21 PM
Telus.net
Not sure about the newer VQ, but the older VE does nothing no matter what you put in it!
Old Jan 8, 2002 | 10:35 PM
Nismo's Avatar
I dont think it would do anything performance wise other than stop pre-ignition
Old Jan 8, 2002 | 10:36 PM
wope's Avatar
it doesnt really do anything..ive also tried that octane booster stuff you put in your tank.
Old Jan 8, 2002 | 10:47 PM
LucentAUTO's Avatar
is there a performance difference between 87 and 91, i sure dont feel it.
Old Jan 8, 2002 | 11:05 PM
Nismo's Avatar
........ until your engine starts pinging
Old Jan 8, 2002 | 11:33 PM
emax02's Avatar
The ECM senses a signal from the knock sensor and retards the car's timing, thus 87 octane does not make the engine ping{maybe one ping}. Of course, anything less the 91 octane on the maxima will hinder performance and give worse fuel economy.
Old Jan 9, 2002 | 12:06 AM
95emeraldgxe's Avatar
100 octane is for those die hard racers that gave their car implants
Old Jan 9, 2002 | 08:11 AM
Tubbed'65's Avatar
it'll let you run some more boost, or make it safer to use nitrous. That sounds like a good fuel to run a SC and a 50 shot to me. Wish it was readily available around here. If you're talking about normal aspiration though thats just throwing money away.
Old Jan 9, 2002 | 08:14 AM
HondaKiller718's Avatar
Old Jan 9, 2002 | 08:35 AM
theblue's Avatar
hope you don't mess up your O2 sensors or cat. I have heard this happens with race fuel.
Old Jan 9, 2002 | 09:05 AM
Synki's Avatar
Higher octane wont do much for our cars. If anything, you might even burn a piston ring running too high of an octane. I dont think our cars push enough power to use such a high octane rating. I have ran my car down past E and filled it with Sunoco 110+ race gas and i noticed nothing different at all.
Hell, i think i feel more using octane booster.
Old Jan 9, 2002 | 10:09 AM
Jeff92se's Avatar
I'm needing a caw
Yeah. But higher the octane the SLOWER the gas burns. Common misconception. So you wouldn't burn a piston. But you might clog a Cat maybe if they use lead to up the octane ratings.
As far as Teles.net, who knows what he's talking about. F1 tranny?
Old Jan 9, 2002 | 10:21 AM
j_bryan's Avatar
yeah as jeff92se pointed out, the higher octane (above the VQ requirement) is basically wasted. although our manual says we need at least 91, i think that is a conservative octane rating. i've recently switched to 87 (from 93) and noticed no performance problems.
Old Jan 9, 2002 | 11:12 AM
ptatohed's Avatar
Licensed to Spell
Re: 100 octane, what a gas...
(4/12)100+(8/12)91 = 94
knight_yyz
Nov 1, 2015 01:34 PM
Andy29
Sep 29, 2015 05:32 AM
JoshG
51
Sep 21, 2015 10:41 PM
sdotcarter
Sep 2, 2015 09:53 PM
